Drivers seat
Old Nov 24, 2024 | 09:13 AM
bunny14th's Avatar
Default Drivers seat
New to forum.
This is our second Crossfire.
@007 Red convert.
Manuel drivers wont adjust.
What is black electrical box attached to bottom of seat for ?
What is hyd cylinder do?
thanks
Old Nov 24, 2024 | 11:14 AM
Default Re: Drivers seat
Originally Posted by bunny14th
New to forum.
@007 Red convert.
thanks
Hi, welcome to the forum.
Is your car a limited, base, SE, or SRT6?
If it's a limited or SRT6 you might have a bad seat relay.
Search the forum for how to replace it. The search bar is in the upper right where it says "Threads". The part is cheap and should be available at most part stores.
If it's a base or SE you might have something stuck in the seat rails that is preventing you from moving the seat.
Old Nov 24, 2024 | 11:34 AM
bunny14th's Avatar
Man seat has a seat relay ?
Is Hyd cylinder for raising the seat ?
thanks
Old Nov 24, 2024 | 11:49 AM
thanks
I still don't know what model car you have. From what you're saying, I will assume that it is a base model. There is no seat relay for the base model, because it doesn't have power seats.
On the driver's seat, left side middle. There should be a handle. That is a pump lever for the hydraulic cylinder. Pumping that lever will raise your seat up.
There is no height adjustment for the passenger seat.
There is a round **** on both seats. That will move the upper part of the seat back and forth. The handle near the floor in front of the seats will adjust the whole seat back and forth.
All of this information can be found in your owner's manual. If you don't have an owner's manual, you can download one here: Owner's manuals, service manuals etc.
Hopefully this was helpful.
Old Nov 25, 2024 | 12:46 PM
Fastenyourseatbelt's Avatar
I bought my first Crossfire a month ago. I believe the electric box is a sensor that determines if someone is sitting on the seat.
The "piston" serves as a strut that aids in raising the seat.
Old Nov 25, 2024 | 02:26 PM
Welcome from a fellow SoCal Crossfire owner.
Old Nov 25, 2024 | 07:55 PM
bunny14th's Avatar
Thanks
Old Nov 27, 2024 | 11:28 AM
bunny14th's Avatar
Seat works !
Just took some GOOD OLE WD40 !
Stuck on rails.
Thanks to all
MercianCrossfire
U.K.
Jul 13, 2021 12:29 PM
smokey847
Jul 21, 2015 11:34 PM
geniegene69
Nov 19, 2014 03:37 PM
Hawk Monster
Sep 26, 2010 09:13 PM
32krazy!
Aug 25, 2010 06:24 AM
