confused
Old Dec 23, 2013 | 03:46 AM
djcpara's Avatar
Default confused
hi guys some help pls on 2 occasions my crossfire has cut out and obviously stopped after 10 mins it starts and goes perfect,someone mentioned I need to replace the camshaft position sensor help
Old Dec 23, 2013 | 04:08 AM
Alicia's Avatar
Default Re: confused
Hello djcpara - I may be the first to read of your need at this early am hour - so let me tell you what I have learned from the forum members. Get a Bosch Crankshaft Position Sensor ASAP. Be sure it is Bosch. Do not mess with facsimile products. Try Amazon as a source if you cannot find one locally. I have noted that this part is the 'magical' solution to many problems such as yours. Good Luck.
This msg is not meant to supersede more knowledgeable advice than what I have, but I have been 'schooled' now for a couple of years on the forum so start your search for the Bosch CPS.
Alicia
Old Dec 23, 2013 | 08:30 AM
She is probably right. Get a Bosch. Autohaus.com or German auto supply.
OOPS, you are in the UK. Not sure where you can go for the part, remember that if you search the SLK320 in the years around 2004, the CPS is the same part.
roar
Jun 15, 2022 11:46 AM
Abaton6
Oct 26, 2016 10:43 AM
Franc Rauscher
May 9, 2016 12:04 PM
leaddog2015
Sep 26, 2015 08:23 PM
Fildo Dog
Jul 6, 2015 05:20 PM
