TCM codes
Old Sep 24, 2014 | 05:41 PM
Jnaber1@fuse.net's Avatar
Default TCM codes
Code reads P0600 and P0750. Where can I find out info on codes
Old Sep 24, 2014 | 07:31 PM
Default Re: TCM codes
Welcome! Where in Cincinnati are you? I am in Delhi. You should be able to Google the codes for more information.
James
Old Sep 24, 2014 | 09:38 PM
Padgett's Avatar
Try the Factory Service Manual (05 is downloadable) under DTC codes (DTC Index page 5) . I take it you have an automagic transmission since both relate to the trans.
Offhand I'd suspect a loose connector for the tranny.
ps sure that is P0750 and not P075x ?
Old Sep 25, 2014 | 09:05 AM
Thanks for the info. Took my car to the dealer and got the codes. They are saying the shifter assembly needs replacing....any sense in this? Quite expensive fix $2500. I asked them to verify the fluid level is OK and check all connections.
Old Sep 25, 2014 | 11:08 AM
I would go this route :
1. replace the transmission connector ( part about $15 )
2. replace the transmission conductor plate ( part around $120 )
3. then think about the shifter assemble, but get one from a recycler. (as low as $35 )
Old Sep 25, 2014 | 01:36 PM
I am having a hard time thinking the assembly would throw the codes. The connector has had problems in the past as well as the conductor plate. I would start there.
rampntlion
21
Feb 11, 2019 08:18 AM
TOPLESS
Feb 9, 2016 11:28 AM
crossfireusa
Oct 28, 2015 12:03 AM
tritongreen
Sep 18, 2015 07:32 AM
MickeyNasty
Sep 6, 2015 08:29 PM
