Need help finding rotors and pads
Old Sep 17, 2025 | 03:18 PM
TBergeson13's Avatar
Default Need help finding rotors and pads
Hi Everyone,Hi, I bought a 2005 Chrysler Crossfire Limited that's been sitting for a little bit and need to do brakes. They aren't the factory brakes and the owner before me said they might be from an 2002 E500 but I couldn't find anything on that and now he won't respond to any of my messages about which car to input the rotors and pads for. I attached a bunch of pictures if anybody can help me out finding the right parts to find. First 5 pics are the front and the last 4 are the rear. Thank you
Front
Front
Rear
Rear
Old Sep 17, 2025 | 04:03 PM
zip439's Avatar
Default Re: Need help finding rotors and pads
If you pull the pads off you may find numbers and or identity markings on the pads.
The rear brakes look to be original.
Old Sep 18, 2025 | 03:16 AM
I was thinking the same thing as zip439.
Pull the pads off of the front brakes and take some close up pics.
All of the rotors should be the same as a 2003 Mercedes SLK 320.
I just noticed there is a Brembo part number on the face of the front brake caliper. I can't make it out, but you should be able to.
You can probably go to the Brembo website or contact them with that part number. Then you will know what pads and hardware that you will need.
Old Sep 18, 2025 | 08:17 AM
NeedsWings's Avatar
i think i have it figured out, message me your email address and i'll have you take some quick measurements to confirm. then we can get you the parts.
Old Sep 18, 2025 | 03:48 PM
Nelson G's Avatar
Read through this post, it's about using C32 bakes as an upgrade for the Crossfire
https://www.crossfireforum.org/forum...tml#post939591
garys383
Oct 31, 2020 01:15 PM
quest88
Dec 5, 2018 11:17 AM
No_Dominion
Oct 27, 2010 04:33 AM
Kit Fox
Jun 17, 2009 08:37 PM
DamnYankee
Jun 17, 2009 07:22 PM
