Other Vehicles The place to talk about watercraft, boats, trains, planes and anything with an engine that isn't a car.
Just bought a new roadster
Old Dec 21, 2010 | 06:32 AM
apkano's Avatar
Life is random...so am I.
Default Re: Just bought a new roadster
Sadly, I'm sure there's more aftermarket for that thing than there is for the Crossfire.
Old Dec 21, 2010 | 09:22 AM
Yeah, I think it is done depreciating. It's value is now intrinsic and related to it's ability to peform useful work
Which is good. At least for my kids.
They can sell it to help pay the inheritance taxes.
Then my son, who helped build the business and our estate in the first place, can keep some of the fruit of his effort.
Though I doubt it will show up at Barret Jackson's.
roadster with a stick
Old Dec 21, 2010 | 01:14 PM
Thanks Doc.
Yes it is an old one. On purpose. No printed circiuts in the electronics. A simple machine.
My neighbor in Hippie ridge has an older D9 and is a diesel Cat mechanic. I'll be fine with older machinery and if I'm in over my head, he will be right there to help. No worries.
Ask around 'cause I would gladly spread some wealth to your hard workin' friends.
I'ts about 400 miles from Decatur IL to Springfield MO.
franc
I am on vacation this week, but I will get on the phone and see what I can do for you....
Old Dec 24, 2010 | 01:27 PM
No worries. I don't need to move it until mid January.
Thanks.
franc
Old Dec 24, 2010 | 01:32 PM
Thanks.
franc
Just the dozer, or dozer/trailer...and can you get me an approximate weight?
Old Dec 24, 2010 | 01:59 PM
Just the dozer with back hoe attached
11,000 to 12,000 Lbs.
The trailer is not included.
franc
BTW had a great eveining with Boiler up and Molly. Awsome couple. You & laura were missed. So, We talked about you, but jusst a little
Old Dec 24, 2010 | 09:10 PM
franc
Sorry, Laura had people in from her new owners of the company...so, she didn't get home early enough to meet up with you. Hopefully, on your way back through, maybe we can meet up....have a Merry Merry....and be safe...snowing here again....
Old Dec 25, 2010 | 03:39 PM
We look forward to hooking up with you guys on Sunday January 2nd.
Weather depending....
franc
Old Jan 26, 2011 | 01:08 PM
Gonna pick my new roadster up this coming Fricay. First real break inthe weather.
Doc, thanks for tryin' but it looks likeI'm gointo do it with my current trailer.
Two 6500 Axles, one with electric brakes. Designed to carry 10, 500 lbs net load weight. The unit is 9,450 Lbsand the backhoe is 1,500. I am justover design limits. But if I load the tonge with about 1,500 of it I should be fine.
For historical reference ( or histerical stupidity) I have had four 2,800 Lb loads of block on the trailer with another one in the bed of the one ton Dodge. Total of 14,000 lbs load and the 3,000lbs of trailer. It was a scary but uneventful trip from Des Moines to my house.
I did 23,700 GVW twice from Altlanta to St Louis using this equipmet. Again scary but I survived an uneventful, albeit stressful, 12 hour drive.
Mostly, I worry about Black ice on I-55.
franc
REAL TRUCKS HAVE DUALLY WHEELS, MANUAL SHIFTERS AND SAY "CUMMINS" ON THE SIDE.
ANYTHING ELSE IS A PEECUP.
Old Jan 26, 2011 | 05:45 PM
franc
Keep in mind heavy equipment trailers have larger framework, and the dozer will be top heavy, so watch the turns. Watch any uneven ground where you will put the trailer in a twist. You could bend the frame. Good luck Franc.
Old Jan 26, 2011 | 11:41 PM
The trailer is a lowboy. And this is a cat trac without a roll cage. That'll help some. I wish I had the load stabilizers and anti sway system on it from my big RV trailer. That would certainly help with control.
I will just take it easy, load the tongue heavy to reduce whiptail and keep the speed under 55 MPH.
I 55 is very flat. So is IL 48 up to Decatur. Big issue is going down to Springfield MO and then the goat trail into my ranch. If the trip to St louis is dicey I will shift strategies.
I have had this rig/combo since 1998 so we know each other well. I should be fine.
Old Jan 27, 2011 | 11:01 AM
We had a great tiome as well! Maybe Laura will let Doc out of the house one of these days
Come drink some bourbon with Molly and I, Doc
Old Jan 28, 2011 | 04:09 PM
Got the thing to St Louis OK. Only had one tire blow up. Tore up a fender and the licence plate.
Did you know if you hit it hard enough one can drive a 16 dp nail through fender steel to rivet something back together?
I know, I know. But, I was out of duct tape.
Only 240 miles to go.
4drturbo
Jan 3, 2019 02:46 PM
crossfire granny
Jul 28, 2015 12:20 PM
Beeker
Jul 20, 2015 03:46 PM
jtr2901
Jul 11, 2015 01:28 AM
jtr2901
Jul 10, 2015 06:33 PM
