TVT265 and TVT450 GB!
Old 09-05-2009, 06:52 PM
TVT_DESIGN
Guest
Posts: n/a
Default TVT265 and TVT450 GB!
We are offering our TVT265 kits for the NA and TVT450 for the SRT6 and a special GB price.
TVT265 includes:
  • Injectors
  • Tuning
  • CAI
  • Phenolic Spacers
Retail for the TVT265 kit is 1450.00, GB price 1200.00.
TVT450 includes:
  • Injectors
  • SL55 Fuel Pump
  • Machined stock SC Pulley (core exchange)
  • Code3 Phenolic Spacers
  • Tune
The above kit assumes you already have an upgraded crank pulley, cooling system, and intake. If not we can work that into the price.
Retail for the TVT450 accessory kit is 1750.00, GB price is 1500.00.
We will need 10 committed buyers for each kit for the prices to be effective. Price is good until 9/30/09.
Old 09-05-2009, 09:03 PM
Bulldogger's Avatar
Default Re: TVT265 and TVT450 GB!
TVT265 includes:
  • Injectors
  • Tuning
  • CAI
  • Phenolic Spacers
TVT450 includes:
  • Injectors
  • SL55 Fuel Pump
  • Tune
With the TVT 450 kit you shouldn't need the injectors with the SL55 pump. I was 380 at the wheels with a straight line 11.5 AFR
Old 09-05-2009, 11:06 PM
What would be the price on the TVT 265 if I already have your CAI? Is Jersey the only place this can be done at?
Thanks
Racehorse
Old 09-05-2009, 11:41 PM
TVT_DESIGN
Guest
Posts: n/a
And I bet your duty cycle was well above 80%. The stock injectors are good for about 450 crank HP at a comfortable duty cycle. Can you run them at more, yes (nitrous doesn't count here). Personally I'd rather see a lower duty cycle, <70%, and have better atomization as well.
Of course with any mod the customer has the choice to do just what is required or to take the additional steps necessary for increased longevity.
TVT_DESIGN
Guest
Posts: n/a
Thanks
Racehorse
The price would be 900.00 for Tune, injectors, and spacers. This can be installed at any competent shop.
Old 09-05-2009, 11:42 PM
TVT_DESIGN
Guest
Posts: n/a
Anyway we can move this to GB?
Old 09-05-2009, 11:44 PM
Whay would be the charge for you to install it?
Old 09-06-2009, 09:01 AM
TVT_DESIGN
Guest
Posts: n/a
250.00 for the install of spacers, tune, and injectors.
300.00 if cai needs installation as well.
Old 09-06-2009, 10:32 AM
Two questions about the 265 kit. One does it come with the engine cover and the badges? And two when would you need the money I was planning on getting it, but I was going to waite untill spring because my car is going in storage pretty soon. Thanks
Old 09-06-2009, 02:07 PM
Voyager's Avatar
you say "assuming you have a crank pulley" i thought the c3 pulley was bad to run with a crank pulley, and so im guessing the pulley is a little bigger than the C3. and what crank pulley gets you 450, and what are these cooling mods?
Old 09-06-2009, 07:21 PM
TVT_DESIGN
Guest
Posts: n/a
We can offer the engine cover if needed. As for the badges, well we have stickers as of right now. The GB price will close on 9/30/09, you can purchase now and we can send or hold till you need it.
Old 09-06-2009, 07:28 PM
TVT_DESIGN
Guest
Posts: n/a
We dynoed with a 178 crank/ 69 SC pulley. Dyno showed 360 RWHP on a Dynapack, which from our experience of running the same car on both a dynojet and dynapack, that equates to about 400 RWHP on the dynojet which most people use.
If you have a 181 or 185 we can machine the pulley larger, if you have nothing we can go smaller.
Cooling mods are a CM30 pump at the very least. So far an upgraded HE has not been necessary for dyno or street driving, but will be for a 1/4 mile burst.
Old 09-06-2009, 08:05 PM
ZAHANMA's Avatar
I begin to worry about the stress on the engine running both a smaller SC pulley and a larger crank pulley.
what stress tests have you done on the engine running the "TVT450" setup?
This also seems to me to be edging out of a daily driver and into race only territory.
EDIT: How much would the price be if I wanted to keep my stock S/C pulley?
Old 09-06-2009, 10:48 PM
TVT_DESIGN
Guest
Posts: n/a
We have 2 DD customers that are having zero issues. The combo runs near the same boost as the 185mm, but with less stress on accessories and less weight on the crank.
If you wanted to keep the stock SC pulley, you really need any of the other parts in our kit.
Old 09-06-2009, 11:44 PM
ZAHANMA's Avatar
I meant if I wanted to go with your machined SC pulley AND keep my stock size SC pulley...
Old 09-07-2009, 01:20 AM
Voyager's Avatar
oh i think he is saying not return the core s/c pulley
Old 09-07-2009, 10:20 AM
TVT_DESIGN
Guest
Posts: n/a
At this time we do not offer that as an option. The pulleys are too hard to find used and too expensive to buy new.
Old 09-07-2009, 01:08 PM
ZAHANMA's Avatar
K, just checking. Trying to keep my options open
Old 09-08-2009, 03:16 PM
What are the power numbers - at the wheel - for the N/A totally stock and with the 265 kit???
Thanks.
Old 09-08-2009, 04:39 PM
TVT_DESIGN
Guest
Posts: n/a
Thanks.
On our dyno we saw 174 RWHP stock and 213RWHP modded.
Quick Reply: TVT265 and TVT450 GB!
