Just added a shot of 75 hp wet nitrous!
Oh man with my other mods this is quite a kick! Well my mechanic said to only use it with the high gears to not damage the transmission. What do you think?
I'm looking to do a 1/4 mile test today and clock my 0-60 to see the changes, the deal is its not an SRT6 and I got the Auto stick!
What should I be getting for a 1/4 mile on a limited xfire? How about the 0-60?
Here is a picture of it before the intrax springs: http://www.freewebs.com/pbsuperti/
Oh yeah I read that a 2004 Crossfire Graphite 6-Speed got 14.92 @ 92.68 mph (stock).
Re: Just added a shot of 75 hp wet nitrous!
Here is a picture of it before the intrax springs: http://forums.superstreetonline.com/...r.php?uid=2347
But Auto's are usually in the 15 flat region. I say you run a 14.4-14.5 @ 96 with the juice.
Yeah that's crazy because with the stock automatic (not using the auto stick) I got 16 sec. 1/4 mile and a terrible 0-60 of 9 sec! So I decided to get the under-drive pulley (13 HP) and to try the ground wire kit supposed to be (3 HP) to add to my other mods before I go down to the track and see the difference.
Originally Posted by Bullseye
That was me...I could have gone 14.8 or even 14.7 if the car's clutch feel didn't suck so much. Not to mention the traction control.
Originally Posted by x'ed
p.s., you know officially own the most powerful non srt-6 crossfire ever on these forums.
Originally Posted by HDDP
Correct, a nitrous bottle will last about 30 seconds... good for drags, but lousy for road racing... LOL... I'll take him in 1 lap... Fastest NA Crossfire to date at California Motor Speedway, Willow Springs, Laguna Seca, Infineon, Buttonwillow, Sandia Motor Speedway, Spring Mountain and PIR is #431...
Originally Posted by golfdude
Bullseye, how does the clutch on the Crossfire suck so much...please enlighten me. For me I feel with a Honda Civic I can down and up shift a bit faster...is this what you mean?
Fidanza flywheel from Summitracing.com
"flywheels require 40 hp to rotate, but fidanza need only 15 hp to rotate from 1,000 to 6,000 rpm. All the extra power goes to the wheels" I guess prices are about $217 - $250 if there is one for the xfire.
Hey the under drive pulleys from EvoSport combined with the ground kit is a really noticeable gain in power. Also the NOS I had installed made me drop 2 sec. of my 0-60 but I have not done the 1-4 mile yet. Later.
I can't really see where your injecting at from your pictures...
From what I've read on the Plymouth Prowler forums, you should not inject the wet nitrous before the throttle body because of the 90* bend on our 3.2 engines' intake fitting. Which causes puddling of fuel on the floor of the intake area, yet causing an nasty leanout condition be careful!
What ground kit ? And did you actually install the under drive pulley's... if so please explain the install process...
did you see it?
Like I said earlier, if your doing the wet NOS (Fuel &Nitrous) don't spray before the 90* intake fitting. Spray after the Throttle body...
