How is the handling balance stock?
I was at nationals this year and the Solstice was definitely the car to have in C - stock. They can fit 285 tires on the stock rear wheels and almost -3 degrees of camber with stock adjustments. Pretty sweet.
Ok does anyone know how much the stock wheels weigh by themselves. I am in search of lightweight wheels to run for next year. Having a baseline weight to drop is important. Thanks.
Originally Posted by Dave OH32
Buy my koseis. 15 lbs.
rear rim: 29 lbs.
Originally Posted by andrew
front rim: 25 lbs.
rear rim: 29 lbs.
rear rim: 29 lbs.
Ok Dave where did you buy your trailer hitch for the SLK? I can probably make that work, since my exhaust will be sliced off anyway to save some weight.
I got it from www.hitchesonline.com it bolts to the SLK spare tire well... with the exhaust gone, you might be able to get it to work, but it'll probably take a lot of work. It was also ungodly expensive... ~ $450 if i remember correctly.
Ok I stopped by the Chrysler dealer today to get a price for the SRT front sway. The parts guy told me his system only lists on bar for both the standard model and the SRT. WTH? I thought the SRT had a larger front bar. If not should I get the AMG front bar or go with the 30mm H&R front bar?
The SRT/SLK32 AMG front bars are the same @ 29mm. If i were you I would go with the H&R bar. As I think it comes with better bushings... If it comes in kit form with the rear bar as well, I'll buy that from you. I know I paid ~$160 for my AMG bar and about $75 for the delrin bushings.
2005 Ragtop
Oct 3, 2015 03:01 PM
