Race Seat Advice
I'm sure it doable, its just too bad manufacturers spend so much time/money to make things difficult. I know its safety stuff but give me a break. A wiring diagram would be such a time saver.
the wire to the seat belt chime is: brown
i have cut my brown wire to eliminate the seat belt chime (wires from the buckle area). this also will eliminate the seat belt symbol on the dash instrumentation.
as for this working when installing an aftermarket seat... i can't answer that one.
Just buy yourself a Schroth 5 point harness and forget about the airbag, seatbelt lights that illuminate on your dashboard. They look really cool, kinda like a christmas tree... LOL.
Originally Posted by HDDP
The female end of the seatbelt buckle is bolted to the side frame of the seat.
The female end of the seatbelt buckle is bolted to the side frame of the seat. This attachment point acts as a ground for the circuit. It's really a pain in the butt to fabricate this thing so it all works after you replace the seat...
Other than the airbag and seatbelt lights, is there any negatives to going this route? Will the ecu limit performance?
... oh yeah ... forget about my brown wire thing ... that won't help w/o the seat.
duh.
I'll look at cutting the wire with or without the seat. Thanks!
Ok, so you recommend forgetting about trying to use the factory belt? You know, I would tend to agree that going with a harness is a lot less painful than trying to fabricate all the stuff to make the seatbelt work with an aftermarket seat.
It's still going to be hard attaching the race seat, you'll probably have to fabricate a bracket to adapt it to the OEM floor rails. I had to make long adapter plates and bolt them into the floor, then attach the race seat to the new rails. Either way you're looking at a good weekend of work.
Where is the best place to attach the harness?
The brackets shouldn't be too difficult, I can get my shop tech to build anything. I know universal brackets are available... are they worth buying or is it best to do it from scratch?
Thanks!
Thanks!
Thanks!
Thanks!
I've seen your harness attachment technique in your gallery. Looks like your bolting to the rear bulkhead. Is this correct? Because my seat will only be used for track days, do you have any other ideas?
Like I said in the earlier post, this process takes some fabrication.
What about buying a factory seat out of a wreck and cutting the foam enough to lower it? I talked to a friend today who did this on his Miata. I want to consider all options before I buy anything.
It will still weigh about 60 lbs though.
I have run standard and full race seats in road cars and the success really depends on what you are trying to achieve, more lateral support, weight saving or both.
There is no doubt that a proper race seat and harness feel much more secure on the track (and the road for that matter!) and allows you to concentrate on operating the controls rather than keeping yourself in place. I find you get a feel more directly connected to the car too.
However, I don't find the stock seats particularly bad for occasional track use; a bit more lateral support would be nice, or more importantly the option to fit full harnesses. But they are much more practical than racing buckets for everyday use - sliding over the side bolster of a race seat to get in and out is a real pain, not to mention sitting on the harness release buckle! A harness is also very restrictive for road use - just think how many times you reach forward to adjust their radio, open the glove box or lean forward at a junction for a better view around a parked car etc. before pulling out. If your harness isn't tight enough to prevent you moving then it will not retain you properly in a crash anyway - thats why we now have inertia reel belts with explosive tensioners. Not all race seats lend themselves to use with the stock belts since the side bolsters prevent the belt from contacting your body properly. You may fine a seat that will work though. The belt fit is something you also need to consider if you are going to lower the seat significantly, since the belt will tent to rub across your neck rather than your shoulder.
The best compromise seats I found for track and everyday use are the Recaro's I fitted to the 911 . They have deep bolsters and harness slots but still have rake adjustment and a quick release tilt - they aren't particularly light or cheap though. It is one area on the car where I have sacrificed added weight for convenience and comfort.
I will consider changing my stock seats in the Crossfire but mainly to gain harness slots so I can snap in a harness for trackdays. First I am going to look at getting the headrest area re-upholstered with slots in.
In terms of fitting a harness the only options for the rear mounting(s) I see are the bulk head, like HDDP has done, or fitting a brace between the rear turrets and fitting the straps to that.
All things considered I would stay with the stock seats if the car is your daily diver and you are just doing occasional trackdays. Otherwise I think you will be creating a marginally better track car and seriously compromising a very nice road car, and thats coming from someone who is prepared to put up with a fair amount of automotive inconvenience for the sake of performance - I used to drive my Sylva Striker (think Caterham 7 without the creature comforts!) everyday all year round it no weather equipment! But its your choice.
Here are the Recaro's in the 911:
Oh and if you do rip out your stock seats they can be put to good use elsewhere. I'm actually sitting on my old 911 seat to type this right now...
Woody,
I guess I should have been more clear about my requirements concerning a seat. I only do 2-3 track events per year. As a result, I don't want or need to do away with my factory seat. Its just that I'm 6'2" and I can't get in my car with my helmet on, therefore I need to drop it at least 1". Also, I have adjusted it as low as it will go and there is simply no way to get enough head room. So, my first thought was to get a race seat for track days only... I always travel with friends so one of them would haul the seat and I would install at the track. This is the reason that I am also seriously considering buying a used XFire seat and having the lower seat pad modified enough to get more head room. Maybe a base seat without electric adjustments would be a good path?
Woody,
