Racing The place to talk about autocrossing, road and drag racing.
Racefire is done...mostly!!
Old Sep 4, 2012 | 03:50 PM
grip grip's Avatar
Default Re: Racefire is done...mostly!!
Originally Posted by hustler316
I'd have to get some data on the trans temps, that being said I also race in manual mode and we have the tcu tune. I feel it's easier on the trans to hold the gear instead of having the computer kick down a gear unnecessarily, time will tell if this is in fact the case. My ECT never got above 235 and my IAT's were 10 degrees above ambient all day. The car is set up almost the same as yours, we have it set just above max. The chassis sheet shows ride height, it was measured from the bottom of the fender to the floor at mid wheel.
hustler316's Avatar
deeeeelete
Old Sep 4, 2012 | 04:47 PM
cjw's Avatar
cjw
We have the front fenders rolled so no rubbing, before the fenders were rolled we were rubbing on that little screw in the middle. That was only under extreme loading though.
Ok. Any chance you can get me some close ups of the fenders. Im wanting 245/40 or 255/35. But i havnt decied on rolling the fenders yet
Old Sep 4, 2012 | 05:02 PM
velociabstract's Avatar
I'll take some pictures of mine if you want. I'm using 255/35/18's on the front and rolled the fenders. (no understeer!) The rolling tool wouldn't clear the calipers and I was too lazy to remove them so the job isn't perfect but most don't notice the shortcut.
I removed my supercooler and went back to stock and my IAT's are more or less the same. I'm thinking perhaps my I/C pump is weak.
Les
hustler316's Avatar
deeeeelete
Old Sep 4, 2012 | 05:14 PM
hustler316's Avatar
deeeeelete
Old Sep 4, 2012 | 05:47 PM
grip grip's Avatar
Do I really need to explain this, seems self explanatory?
I should have said that I was shocked you're only seeing 10F over ambiant. I figured it was a typo.
Old Sep 4, 2012 | 05:53 PM
hustler316's Avatar
deeeeelete
Old Sep 4, 2012 | 06:24 PM
If you'd like I can post up my corner weights and ride heights for comparison. Well if I can find them.
Les
Old Sep 4, 2012 | 06:39 PM
hustler316's Avatar
deeeeelete
Old Sep 4, 2012 | 07:09 PM
It took a while to find the "after" photo. This is with me in the car, small battery, no passenger seat and 1/4 tank of gas. When I get the car on a level spot I'll measure the height to the top of my fenders.
Old Sep 4, 2012 | 08:04 PM
Squirrel Crusher's Avatar
Very Interesting. I'll keep watching for updates and Good Luck.. Squirrel Crusher
Old Sep 4, 2012 | 08:09 PM
LOL so were the guys at the tuning shop.
I've got a buddy with an E55 AMG and he only reaches 140º IAT's at 150 mph approximately. I've gotta figure out why mine are out of control. Timing gets pulled from around 24º BTDC to 16º. 10º over ambient is a dream number for me. Do you have the thermal coated intercooler?
Les
Old Sep 4, 2012 | 08:23 PM
hustler316's Avatar
deeeeelete
Old Sep 4, 2012 | 08:32 PM
I was using Tighed 1's cooler which is similar except it's single pass. I took it off around a month ago to see how much my ECT's would drop. They came down 5º more or less and my IAT's went up 5º more or less. Another reason for removing it was to have space for a transmission cooler in the front. I'm still going back and forth on that one. I have a new I/C pump coming in the near future. Eliminating the possible causes.
Les
Old Sep 4, 2012 | 08:38 PM
hustler316's Avatar
deeeeelete
Old Sep 4, 2012 | 09:08 PM
grip grip's Avatar
I guess you should have got Rob's lol, you too could have 10 degree above ambient.
I have Rob's and I'm seeing 15-20F over ambiant under 60mph, then 25-35F over between 77-85mph.
Old Sep 4, 2012 | 09:14 PM
  #38 (permalink)
hustler316's Avatar
deeeeelete
Old Sep 4, 2012 | 09:30 PM
  #39 (permalink)
I never go UNDER 60! Well, driving to the track I do.
Les
Old Sep 5, 2012 | 06:22 PM
  #40 (permalink)
Ok, got off my lazy backside and measured the ride height. This is with the passenger seat, full size battery, 1/4 tank of gas and 40 lbs of tools in the trunk.
Drivers front 25 1/8" Passenger front 25"
Drivers rear 26 1/2" Passenger rear 26 3/8"
Les
hustler316
Racing
27
Jan 10, 2017 09:19 PM
hustler316
Aug 11, 2013 04:17 PM
hustler316
Aug 5, 2013 07:04 PM
hustler316
Jul 30, 2012 08:37 PM
danhaman
Feb 2, 2009 03:53 PM
