Rcm problem
Old Jan 18, 2019 | 05:28 PM
oldtweety's Avatar
Default Rcm problem
Just bought 2004 crossfire, drove it for a month and check engine came on. Pulled the RCM and soldered the 3 little culprits, placed it in and light went away for a week and came back. Diagnosis was P 0410 any suggestions
Old Jan 18, 2019 | 06:01 PM
Default Re: Rcm problem
Pull it again and send an email to tighed1@hotmail.com
He will send instructions on where to ship and where to pay.
It needs an air pump relay replacement.
Old Jan 18, 2019 | 07:51 PM
read this one
https://www.crossfireforum.org/forum...-new-post.html
Old Jan 22, 2019 | 06:23 PM
oldtweety's Avatar
Thanks for advice pulled it out again cleaned off solder and let my wife solder it, she once worked at a tech company, started right up and engine light was off, runs great and smog pump works should I still replace air pump relay valve or wait, 34000 miles on it
Old Jan 22, 2019 | 06:26 PM
Originally Posted by ********
Thanks for advice pulled it out again cleaned off solder and let my wife solder it, she once worked at a tech company, started right up and engine light was off, runs great and smog pump works should I still replace PCs valve 34000 miles
Replace whatever you want but the wife's a keeper.
Old Jan 22, 2019 | 09:07 PM
tighed1's Avatar
The fault will come back. Look at the contacts on the relay on the end of the board. They are burnt! Relay needs to be replaced.
Contact that tighed1 guy as mentioned for repair info. Heard he does pretty good work!
Old Jan 23, 2019 | 10:43 AM
I am not so sure that the RCM is at fault, has anyone seen the burnt relay? That fault is caused by a few problems, if the pump works every time it is not the relay.
We have to make sure that the fault is diagnosed before suggesting to the OP that he spend money on something that is the wrong; doing that we become just like some dealers who change everything until the fault goes away.
firefly04
19
Sep 11, 2021 03:22 PM
cossbreed82
Oct 27, 2013 04:22 PM
mhoward0058
Feb 6, 2012 07:42 PM
livefreeordie
51
Oct 11, 2010 01:14 PM
chelseaccox85
Dec 18, 2008 01:16 PM
