erratic temperature
Old Jun 29, 2006 | 06:43 AM
Buck70's Avatar
Default erratic temperature
Anyone know where the outside (air) temp sender is located on the '05 SRT6, so I can check the ground/connector etc.?
While driving around our display shows a swing of about 15* on a typical outing. Not a heat soak issue from the radiator, I'm talking about after it settles in, then wanders 10-15* colder than ambient, then back to normal.
Bad ground, bad sensor, loose connector, dunno??
Thanks,
DB
Old Jun 29, 2006 | 07:36 AM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: erratic temperature
its located in the driver side lower grill area.
the lower grill will pull off and you'll have full access.
~ a couple pics to assist:
Old Jun 30, 2006 | 07:27 AM
Buck70's Avatar
Andrew
Thanks for the pics and location. Should be an easy deal now that
I know where/what to look at. You coming to the SRT Nats in July?
DB
Old Jun 30, 2006 | 09:31 AM
+fireamx's Avatar
Totally off the subject, but after seeing what's behind the lower factory grills, I may be only interested in purchasing the upper grill from CTD of Germany.
Old Jul 1, 2006 | 08:38 AM
Kit and Kat's Avatar
Hi,
We must be fairly close to each other, have you checked to see if the fan is blowing the right way? I had the same issue...yesterday.
Old Jul 1, 2006 | 10:00 AM
+fireamx's Avatar
Originally Posted by Kit and Kat
Hi,
K and K, I think Buck70 was talking about the outside air temp read out, not the engine temp.
waldig
Sep 17, 2015 10:35 AM
waldig
Sep 2, 2015 11:02 AM
Wolf_7
Aug 26, 2015 06:37 PM
Rets
Aug 11, 2015 06:27 PM
Ralph289
Jul 26, 2015 12:52 PM
