Looking for a flywheel
Old Nov 7, 2006 | 10:17 PM
psuperti's Avatar
Default Looking for a flywheel
Can anyone tell me if they had any luck finding an aftermarket performance flywheel for the crossfire?
Old Nov 8, 2006 | 01:29 PM
Dave OH32's Avatar
Default Re: Looking for a flywheel
I can tell you that I've had no luck finding one, unfortunately.
Old Nov 8, 2006 | 05:19 PM
psuperti's Avatar
Thanks, hope someone can find one.
Old Nov 9, 2006 | 11:03 AM
HDDP's Avatar
Same here... Closest I got was having Spec Clutch make one...
Old Nov 9, 2006 | 12:21 PM
dynamicS's Avatar
Maybe you can try doing a search for the 6 speed trans in other cars, Who makes our trans, is it a Getrag 6 speed?
Old Nov 9, 2006 | 02:25 PM
psuperti's Avatar
They made you one? Can I have their contact info?
Old Nov 9, 2006 | 10:47 PM
HDDP's Avatar
Perhaps I should have said, the closest I got was having spec clutch agree to make one. I have not had them do it yet... I'm building a full 112 engine from scratch and have quite a few things that will be modded, including the flywheel.
http://www.specclutch.com/
Old Nov 10, 2006 | 12:36 AM
dynamicS's Avatar
Hey sounds like a candidate for a full documentation thread. I would love to see pictures and follow along on your build.
Old Nov 10, 2006 | 01:08 AM
HDDP's Avatar
By the time it's (I have the extra money to complete it, next summer) you probably won't have your Crossfire any longer since it seems you're so dissatisfied with it... I already have the short block which was ported / polished by Extrude Hone. Everything else is waiting on $$$.
Old Nov 10, 2006 | 02:06 AM
dynamicS's Avatar
Well it may be some time before I find a replacement, I'm not entirely finished with the XF, just tired of DC and their hack mechanics.
What else are you planning for the short block build? I'm curious as to what the cfm flow was before and after your extrude porting, I know it'd a very expensive process any reason why you choose to go that route instead of CNC porting??
Old Nov 10, 2006 | 03:44 AM
HDDP's Avatar
I bought a used short block from Metric Motors in Woodland Hills and had it ported / polished at the Long Beach facility of Extrude Hone. The process is very pricey $1,900 for the block, intake manifold & exhaust manifold.
I'll fill you in a bit more as the rest of the build progresses...
Old Nov 10, 2006 | 02:12 PM
dynamicS's Avatar
OK I look forward to hearing updates. Did you port the heads too? I would get them flow tested first before modifying and spending anymore money on them.
sk8erjosh09
Apr 24, 2014 11:53 AM
kinkladze
U.K.
Jun 8, 2013 01:33 PM
sk8erjosh09
Mar 6, 2013 11:20 AM
JeffS
Dec 1, 2011 11:35 PM
Holycrap
Feb 28, 2011 11:42 PM
