whine when fan is on
Old Jun 20, 2007 | 11:10 AM
capstain's Avatar
Default whine when fan is on
It started yesterday, I was on my way home from work with the AC on and suddenly a loud whine started. I turned the AC off but the whine was still there as long as the fan was on. Once I turned off the fan the whine went away. This morning I just turned on the fan without the AC and the whine started up again.
There doesn't seem to be any problem with the engine. The AC also seems to work fine. The whine only occurs when I turn on the fan. Has anyone else had this problem and is there an inexpensive solution? OH, by the way I have an '05 XF coupe.
Old Jun 20, 2007 | 12:01 PM
CrossfireLTD's Avatar
Cool Re: whine when fan is on
This could be the problem.
TBS: 30-Mar-06 - E19 - Campaign - Cooling Fan and or Motor Assembly Replacement.
Old Jun 21, 2007 | 07:12 AM
bobs's Avatar
Default Re: whine when fan is on
LTD, I think he's talking about the A/C fan. Capstain, you probably have gunk in the A/C blower housing. When's the last time you changed/cleaned your cabin air filter? You might want to pull it out and check if you haven't done so in a while.
Old Jun 22, 2007 | 09:18 PM
ste7of1's Avatar
I had a somewhat similar problem. Actually had smoke come from vents first, then whine. Dealer replaced blower unit. After that fan started running erratically at which point they replace a resister in the new unit and everything seems to be okay since (about a month).
Ste7of1
Old Jun 22, 2007 | 09:39 PM
Oops, the title through me.
My wife always whines when I turn on the ceiling fan in the bedroom.
Old Jun 22, 2007 | 09:43 PM
RPM's Avatar
RPM
Moderator
- Mine too.
Valk
Jul 12, 2021 09:49 PM
Oct 1, 2015 01:42 AM
pop49
Sep 30, 2015 11:14 AM
RiderJC
Sep 7, 2015 11:19 PM
williammt
Sep 6, 2015 11:23 AM
