Redline with the ESP fuses pulled!
Old Aug 25, 2007 | 12:22 AM
apkano's Avatar
Life is random...so am I.
Default Redline with the ESP fuses pulled!
I was proven wrong tonight...it IS possible to get to redline with the fuses pulled for the ESP program. (fuses 17 & 18)
http://www.youtube.com/watch?v=RwRK97G2lFM
I got completely sideways in second. (not in the video...I had to steer, shift, and hold a little camera on Michigan roads! Gimme a little slack!)
I had to make a video of the tachometer just to prove it can be done!
Old Aug 25, 2007 | 02:16 PM
HDDP's Avatar
Default Re: Redline with the ESP fuses pulled!
I guess I was proven wrong as well... It surely doesn't work on my 2004 6 spd though... And I've tried a dozen different times... Finally had to disconnect the YAW sensor...
Old Aug 25, 2007 | 02:19 PM
apkano's Avatar
Ya...it surprised the hell out of me too! I still think I'll keep the fuses in though...I don't like the thought of giving up my ABS and stability for driving in traffic.
Old Aug 25, 2007 | 02:30 PM
MMZ_TimeLord's Avatar
Don't forget that your front wheels were in motion. If you try that on a dyno, it may top out at around 5,000 RPM. Or if you try to do donuts, because of the YAW sensor input.
Nice video though.
Cheers!
Old Aug 31, 2007 | 07:09 PM
stallion8797's Avatar
Banned
How do you disable the yaw sensor?
Old Aug 31, 2007 | 07:59 PM
woody's Avatar
Just disconnect it, and live with the BAS/ESP light being on all the time.
PS. If you do disable the ESP be careful, the rear will break away quite suddenly when it does go.
Old Aug 31, 2007 | 09:17 PM
apkano's Avatar
So I've noticed!
Old Aug 31, 2007 | 10:34 PM
Banned
OK I may sound stupid but, is there a fuse for it? A plug? A "disable yaw sensor" button?
Old Sep 1, 2007 | 05:21 AM
HDDP's Avatar
It's a wiring harness connector that attaches to the sensor... Just press the side tabs and pull... If you don't know where the YAW sensor is, it's located under the center console just aft of the shift mechanism.
But as Woody said, you will throw a light on the dash... But it will go away after a couple of driving hours after you re-attach the sensor wires...
Old Sep 19, 2007 | 08:26 AM
Z28toXFire's Avatar
I think i pulled the right sensor. is it located next to the hand brake, behind the shifter. i got under there and pulled the first thing i saw that matched what you said it was. the ESP BAS light came on i couldnt control the TC and so i thought i was in business, but come to find i cant rev over 4000 RPM and it bogs down worse than ever.
Justin Mahaffey
Old Sep 19, 2007 | 09:14 AM
Z28toXFire's Avatar
Hey i also just went out to my car right now to check the fuse box on the inside of the car like i read elsewhere on this forum but the fuses on the inside dont go to 18 only 14 and 13 and 14 are not used. the fuse box inside the engine bay have 17 and 18 as spares, and they were empty when i checked. please someone assist me here.
Justin Mahaffey
Old Sep 19, 2007 | 12:18 PM
DanielNTX's Avatar
Justin Mahaffey
From what I've been reading, I think it's different between manual and automatic.
Old Sep 19, 2007 | 07:20 PM
sharptech's Avatar
i disconnected my yaw sensor as well just now and the esp light does come on but the trac light in the dash stays off and i have no control over it. i can rev to 6k still but traction control is on and stays on. next i am going to try disconnecting the battery and that makes the esp light and trac light come on but i don't know for how long.
Old Sep 20, 2007 | 10:38 AM
sharptech's Avatar
Nope no luck. I also tried disconnecting the middle fuse labeled traction, in the little box over by the battery and the abs and esp light came on but I still have traction control.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Reliableron
Oct 17, 2015 10:19 PM
Selbyl
Sep 22, 2015 10:41 PM
tritongreen
Sep 18, 2015 07:32 AM
Bob4kacz
Sep 16, 2015 11:20 AM
