The official eaton supercharger thread.
Old Jun 16, 2008 | 08:33 PM
alky68's Avatar
Default Re: The official eaton superchrger thread.
nic very nicw hope it all works out intrested on see more pics instal pics as well
Old Jun 17, 2008 | 10:08 AM
BlueStorm's Avatar
Originally Posted by ChuckNorris
This one is the oval port . But its not like I can really run a lot of boost anyway. The manifolds are so simple you are gonna laugh. I'm planning on trying a light epoxy coating on the lobe tips since that is where they seal. I'm also polishing the internals and going to run my methanol/water injection through the SC. This reportedly increases efficiency and cools the supercharger and is recommended on many sites including the site I bought my kit from.
I bet it wouls be easier to send it off for a thick plate of chrome, that will tighten up the gap clearance
Old Jun 17, 2008 | 10:11 AM
BlueStorm's Avatar
PM me your email adress Chuck, I have an installation manual for adding a German aftermarket centrafugal Supercharger to the m112. found this a long time ago, but it will show you how to relocated some parts. maybe it will help you out.
Old Jun 17, 2008 | 06:56 PM
ChuckNorris's Avatar
Chroming is an awesome idea. I bet it would keep the heat down as well.
Old Jun 18, 2008 | 10:01 AM
BlueStorm's Avatar
Did you get the supercharger installation manual?
there is a little page showing the hook up of the FMU system installed and where vacum should be pulled too. hope it help, some parts may require a little bablefish translation but you should be able to figure it out.
Old Jun 18, 2008 | 11:20 AM
Got the manual, remarkably similar to what I'm doing. Thanks, I did get some ideas out of it.
Old Jun 19, 2008 | 09:37 AM
Got a new coupler for the sc. The old one has a spring that wears out. The new one is a solid composite design. It's installed onto the snout in the picture. I've decided to hold off on modding the supercharger any further until I see what kind of boost its actually going to build. Manifold pics should be posted by Saturday.
Old Jun 19, 2008 | 04:43 PM
Maxwell's Avatar
I would be interested in buying a manifold from you Chuck. let me know how much it will cost.
I just don't have time or the energy to pull my welder out of storage. would you like to do a group buy on this, maybe we can get 10-20 people in on this, make it worth your time, ay?
Old Jun 19, 2008 | 04:52 PM
HyprLtH20's Avatar
www.CustomCrossfire.com
i would be interested in getting in on this! how bout it Mr. Norris?
Old Jun 19, 2008 | 05:09 PM
BlueStorm's Avatar
I would love to get one myself, Chuck. how much?
Old Jun 19, 2008 | 07:34 PM
Right now I am more interested in making everything functional.
Old Jun 19, 2008 | 07:42 PM
HyprLtH20's Avatar
aka: "do it yourself!" lol jk
Old Jun 20, 2008 | 10:36 AM
Maxwell's Avatar
sounds cool to me, hope it all works out smoothly. keep us posted
Old Jun 20, 2008 | 11:32 AM
Will do. I'm not saying that I would never be interested in building and selling intakes. I'm just in no position to do such a thing at the moment. Within the next two months it may become possible.
Old Jun 22, 2008 | 10:25 AM
I had some clearance issues with the first set of manifolds so I'm starting on a new set.
Old Jun 22, 2008 | 12:06 PM
Maxwell's Avatar
how are you going to make the mounting flange that bolts to the heads?
Old Jun 22, 2008 | 12:40 PM
I'm hand cutting and port matching out of 1/2" Aluminum plate. I transferred the exact shape with paper and charcoal. It takes a lot of time, hopefully it will be worth it.
Here is a link for some intake building basics.
http://www.popularhotrodding.com/tec...lds/index.html
Old Jun 22, 2008 | 01:09 PM
  #38 (permalink)
Maxwell's Avatar
how far deep are the injectors located? are they mounted in the head or the manifold?
Old Jun 22, 2008 | 01:57 PM
  #39 (permalink)
The flanges are setup nearly identical to the factory flanges. The injectors end up being about 1/8" closer to the intake valves because of the difference in flange thickness. The clearance problem I had was with the fuel injector rail. My runners were too upright and the rail would not go back on. My next runners are going to be canted towards the supercharger to get around this. I'm aiming for the runners and plenum volume to equal 3.2 liters. I should have some results posted by next weekend.
Old Jun 22, 2008 | 03:45 PM
  #40 (permalink)
Maxwell's Avatar
absolutly wonderful, except for the little set back. looking forward to the pictures! have a good week end
