2005 Auto stock in Limp mode, won't shift
Old Jul 19, 2008 | 05:39 PM
300zx's Avatar
Default 2005 Auto stock in Limp mode, won't shift
Hi All,
My 2005 Crossfire is stuck in limp mode where it won't shift further than the first gear, it is automatic.
Car got into this condition, after my wife left the top down and it rained, getting engine code P0705 which is PRNDL SLA shifter lever assembly.
Took the shifter appart and cleaned it, did not see any evidence of water.
the supply voltage to this assembly is present, the little LCD block in the dash is blacked out.
I think the shifter assmbly is gone bad, has it happened to any one?
I am not sure if I buy a used shifter lever assembly whether it will work, or whether it require dealer programming in order to mate it wiht the tranny ECU.
I did search and I did see similar behaviour, but it was not caused by rain/water.
Also , if any one has the service manual for this car and willing to share it, that would be great.
Look forward for your input.
Thank you,
Rafi
Old Jul 19, 2008 | 06:19 PM
Iamfink2's Avatar
Default Re: 2005 Auto stock in Limp mode, won't shift
This is what the code is: P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
Old Jul 20, 2008 | 06:57 AM
Kurts's Avatar
Check out the link below.
MMZ Timelord spent mucho time & effort to download a whole bunch-o service manuals to the Forum. I'd bet that the '04 Coupe service manual will be appropriate....not many changes between the '04's & '05's, if any.
Good luck!!
https://www.crossfireforum.org/forum...ad.php?t=13875
Old Jul 20, 2008 | 12:05 PM
300zx's Avatar
Thank you for the info, I am almost 100 percent certain that my shifter assembly is bad, so, I know I am looking for a replacement.
Cheers,
Rafi
tom2112
Dec 1, 2015 09:02 AM
Buchacho
Jul 22, 2015 12:56 PM
axnguyen
Jul 21, 2015 11:41 AM
XFIRED-TX
Jul 14, 2015 10:48 PM
Rusty475
Jul 13, 2015 10:03 AM
