Amplifier hiss
Old Dec 10, 2003 | 02:46 PM
ntmatter's Avatar
Default Amplifier hiss
I notice that I get a constant hiss from the speakers, whether or not my radio is turned on. I'm assuming that the stereo amplifiers are running on switched power independent of the radio and are so always on, is anyone else having this issue?
Old Dec 10, 2003 | 06:08 PM
DFWSBR's Avatar
Default
Swap out the radio. It is not common. The TSB is out there anyway. If it doesn't fix it, have the tech go to step 2. Maybe replacing the amp?
Old Dec 18, 2003 | 11:14 AM
robby's Avatar
Default
my car is doing the same thing... i have a few posts on here that say "white noise" i just found out today that it was probably the amp when i took my car in... they're going to order a radio for me i think!
Old Jul 26, 2004 | 02:58 PM
deco's Avatar
Default
Anyone have new info or clues on this since last posting in December?
My car just developed this. I turn on ignition, all is good. At exact moment car revs down to 700 RPM, right door speaker starts hissing, white noise at about 1KHz range. If you put your ear up to the other speakers you can hear it much softer, it's worst in the right door.
This occurs with radio OFF. But you can hear it when radio or CD player is on, too.
What would push power thru a turned-off amp? Noise seems to increase as speed goes up (just like radio does when on).
I assume amp is not always on because it takes a few seconds to get sound when I turn the stereo on.
Radio was swapped out in March because of LED issue.
mobilefitt
Jul 28, 2015 03:45 PM
pioneer4x4
Jul 27, 2015 02:04 PM
blackcrossfire07
Jun 28, 2009 09:35 PM
michaelsaphireblue
Jun 28, 2008 01:53 PM
Chris_Von_Bron
Oct 24, 2007 05:36 AM
