water and IAT temps.
Old Nov 10, 2011 | 08:59 AM
Default water and IAT temps.
what i have done to get the temps down, is very simple,, Rob at Needswings was a great help in getting this done ,and you too can have your own system, Rob told me he would make this system but only on a build on order only , two heat exchangers ,one behind each fog light (fog light removed of course) here is the video of my car after hours of hard running, the temp as you can see is 71* don't forget this was with my sl55 with no inlet tubes on it just engine bay air,,, you can see boost ,,rpm,,speed, water temp IAT and spark adv. jim
pbir11-9-11tempengIAT.mp4 video by amx1397 - Photobucket
Old Nov 10, 2011 | 12:14 PM
ZAHANMA's Avatar
Default Re: water and IAT temps.
Jim, this is pretty fantastic.
One thought for you or Rob, is there a potential to place the two heat exchangers almopst parallel to the ground right behind the fog lights to keep the fog lights in place, but still get the necessary air across the heat exchangers. Seeing as right below the fog lights is just mostly an open area (with the exception of the ic pump on passenger side).
Also, any clue as to cost? Even if it is on abuild to order basis.
Old Nov 10, 2011 | 12:20 PM
Sounds like a good idea. Are the heat exhangers part of the engine coolant system, or just for the IC system? I know you have the coolant system seperated.
Also to let the heat out of that fog light area, did you leave the access doors off?
James
Old Nov 10, 2011 | 02:08 PM
James
I was going to connect one to the coolent system and the other to the IAT system,, but i tried both to the IAT system ,, this worked the best for me. i had also installed a fan on the radiator from a hemi truck. the small door in the rear of the fog lite did not exhaust all the air that the heatexchanger could flow so i opened it up,,, guess what ,,it also cools my brakes what Rob is doing is making the HE with Fan and mounting brackets ,,you could mount it where you want and to the radiator or the IAT water system,you could try the flat idea it may be all you need. here are some pic of mine mounted both to the IAT system. don't know about the price ,,Rob told me he will let me know in a week or so what mine cost.
Old Nov 10, 2011 | 02:23 PM
velociabstract's Avatar
Hey Jim. I wanted to keep my fog lights if possible so I'm installing the stock H/E in front of the supercooler. It won't work as well as your solution but I hope it's enough for now. The Hemi fan is almost a certainty for me seeing how it works wonders on your super car. I'm glad you and Rob are sharing this solution.
Les
Old Nov 10, 2011 | 02:41 PM
grip grip's Avatar
Subscribed. This will be a great winter project.
Old Nov 11, 2011 | 02:48 AM
Mimi05SRT6's Avatar
Awesome Jim. After talking with you on the phone, I was wondering what the gauges actually looked like. That is an awesome piece of technology! See you soon and I'll try to stay with you in the 1/8th mile at least!
Old Nov 11, 2011 | 05:16 AM
32krazy!'s Avatar
nice! any pics of the h/e installed with the fans andbumper cover off? would love to see the setup in full as i want to keep my fogs. the slk32 actaully has a bigger screen area around the fogs so it should be able to be done
Old Nov 11, 2011 | 10:45 AM
sorry didn't get any pic with bumper off . here are all my pic of the new heat exchangers, notic i added a spoiler under the car to get more air to the radiator. jim
Old Nov 11, 2011 | 10:52 AM
and the others,, I think this is all i have. jim
http://s264.photobucket.com/albums/i...ngthev8003.jpg
http://s264.photobucket.com/albums/i...ngthev8004.jpg
Old Nov 11, 2011 | 02:11 PM
32krazy!'s Avatar
were did you find the fans and coolers jim? did you run all 3 h/e in parallel with the cm30 or did you go with a bigger pump?
Old Nov 11, 2011 | 03:05 PM
stock pump,,,Rob got the HE and the aluminum housing and the fans were already mounted ,, all i did was buy 3/4 and 5/8 heater hose, remove the plastic box behind the fog light and, plum them in and wire to a relay to my key on, reinstall the plastic, done. i was thinking of some mesh or something both front and rear to keep the rocks away, bu so far not needed,, also went through a lot of water a few weeks back everything still works. jim
Old Nov 11, 2011 | 03:39 PM
I just did a sound video for you the engine is not NOT running just the fans, this sound alone scares most chevys away . try it with a headset on ,,,wow.
MOV00861.mp4 video by amx1397 - Photobucket
Old Apr 10, 2012 | 09:13 PM
grip grip's Avatar
I'm really considering this mod once again.
Old Apr 10, 2012 | 10:11 PM
JesseJamessrt6's Avatar
yeah, thanks for bumping this.
cppeabody
Sep 15, 2015 08:43 AM
williammt
Sep 6, 2015 11:23 AM
waldig
Sep 2, 2015 11:02 AM
waldig
Jul 29, 2015 06:54 AM
Ralph289
Jul 26, 2015 12:52 PM
