engine runs rough, loses power
Old Nov 13, 2011 | 09:35 AM
hemibeep's Avatar
Question engine runs rough, loses power
I was driving the car the other morning, the car started to run rough at redlight, then had no power, would not go above 1200 rpm, no throttle response. I cleared the intersection, and it cleared up and ran great the rest of the day. It was acting like there was water in the fuel? Then yesterday, it did the same thing from a cold start in driveway. I turned off, restarted, and it was fine.
ANy thoughts?
thanks
2005 srt
Old Nov 13, 2011 | 09:39 AM
tighed1's Avatar
Default Re: engine runs rough, loses power
WELCOME TO THE FORUM!
Search for CPS or crank position sensor.
Sounds like your problem.
P.S. You can visit when you don't have car problems too!
Old Nov 13, 2011 | 10:47 AM
MikeR's Avatar
I think DJ has this one pegged.... that was how my CPS failure started... only at the track!
Old Nov 13, 2011 | 11:34 AM
waldig's Avatar
Talking Re: engine runs rough, loses power
Confirm the integrity of the rubber seal between the throttle body and the supercharger also, they can split and open the intake, the engine goes into limp..Woody
Old Nov 16, 2011 | 07:00 PM
hemibeep's Avatar
So I ordered the new CPS and start to install. I notice the part of the wire clip laying next to the sensor on the bellhousing. Any tips how to replace the clip that locks the connector into place?
Old Nov 17, 2011 | 12:25 AM
MikeR's Avatar
You will have to replace the connector as the latch is part of the connector housing (PITA)...... so was the connector loose and causing your problem?? or still firmly connected but with broken latch??
Old Nov 17, 2011 | 04:39 AM
hemibeep's Avatar
It seemed tight, but i do not trust it without the clip
Can I just buy a new connector and solder into place? Part number?
thanks
hemibeep's Avatar
thanks
Old Nov 17, 2011 | 05:32 AM
thanks
Alabama shade tree solution : find ( or construct ) a piece of metal about 1" long with 2 holes in it the size the retainer screw will go through.
Bend it to 90 degrees and bolt the CPS on with it under the bolt.
Use a couple of small tie-wraps, one around the wire before the connector, the other through that one and the other hole in the bracket you made.
Voila'
Old Nov 17, 2011 | 07:35 PM
hemibeep's Avatar
i actually made two wraps of electrical tape on the sensor. Quite a tight fit. I do not think it will be an issue. thanks to all!
Old Nov 23, 2011 | 05:20 PM
hemibeep's Avatar
Exclamation Now what?Re: engine runs rough, loses power
So I installed new CPS and today, when leaving work. car started but ran rough and almost stalled. I re started three more times, then it ran fine all of the way home, including a fuel stop.
What should I check next?
Old Nov 23, 2011 | 05:26 PM
I hate to say this, but it has happened. Some of the CPS sensors are bad from the get go. You wouldn't think it, but there it is. You had connections problems with it as well. It must be seated properly to work. Just a few thoughts. It sure is acting like a CPS sensor.
Or am I wrong and you just installed a second one?
I know this is reaching a bit, but do a couple of "throttle resets"... The throttle position sensor could be causing a hesitation which would make it idle rough at first start up...
Old Nov 25, 2011 | 05:02 AM
hemibeep's Avatar
I cannot find the "how to" for the throttle position reset. Should the normal idle be just above the small hash between 0 - 1000 ?
Old Nov 25, 2011 | 05:03 AM
hemibeep's Avatar
Also, when it acts up.... attempting to throtte has no response.
Old Nov 25, 2011 | 09:31 AM
the throttle reset is pretty simple to do, so here goes. Turn the key to the ON position. Just ON, don't start it. Now press the throttle all the way to the floor board. Hold the throttle down for a count of 5, now keep holding the throttle down, and turn the key OFF. Now, let the throttle off. Give it a few seconds to do it's reset. This doesn't always work the first time. Kind of like resetting the oil change indicator. LOL...PITA... The throttle by wire has a sensor as well, and well as the throttle itself. I had the rubber cover run up the post on mine, caused it to stick one day. Others have had the floor mat get tangled up causing the throttle to stick. Make sure all is well with the throttle peddle itself. Not bent to one side, or the rubber cover distorted. At least worth a try, and it does need to be reset from time to time. The car's memory will affect performance. Good luck
Kodebuster
Nov 5, 2020 04:06 PM
jgreen
106
Sep 18, 2017 11:46 PM
axnguyen
Jul 21, 2015 11:41 AM
ricardo 53
Jul 21, 2015 07:49 AM
cjfine
Jul 20, 2015 11:58 PM
