Lots of trouble going into Reverse, need some help
Old Mar 10, 2012 | 01:48 PM
WestKyOnXFire's Avatar
Default Lots of trouble going into Reverse, need some help
To open up, this is my first post. I bought an '04 Crossfire 6-speed, low miles yesterday. My only problem with the car is that at times I have a tremendous amount of trouble going into reverse. I realise the lift up, left-back idea, but still, after driving somewhere, parking and coming back out, it is a pain. I have checked the TSBs and Tech forums to no avail, none seem to address my exact situation. Any thoughts/suggestions would be greatly appreciated.
PS I have no trouble getting it in reverse after it has set through the night.
Edit: After realising I didnt explain it very well, here is my issue. I pull up on the ****, left and back, but then nothing. I can yank, heave, tie the **** to a rope and the rope to a horse, and it still wont go into gear (slight exageration for effect). But eventually with some wiggling it will just drop in.
Old Mar 10, 2012 | 03:01 PM
MoparFreak69's Avatar
Default Re: Lots of trouble going into Reverse, need some help
An old habit I have from many years of driving a stick is to shift into 2nd before I go to reverse. Just a quick drop in and then out and over to reverse usually lines things up so it will fall right in. With transmissions that have reverse on the right side I do 1st then reverse. Just seems to line the gears up more closely so that reverse can just slide in (reverse is usually a straight cut gear instead of angled like the rest of the gears).
Old Mar 10, 2012 | 03:37 PM
I appreciate the quick reply Freak, I have owned a couple of other manuals before and hadnever had this problem. I assumed that it might have something to do with reverse being on the lower left, as I have never owned a manual that had reverse in that position. I will try what you said right now and see if she works. Thanks!
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Mike OD
Sep 23, 2016 07:00 AM
Mackel
Oct 16, 2015 09:03 AM
FISHBONE
Sep 17, 2015 06:15 PM
RacerXofFL
Sep 15, 2015 05:00 PM
