Transmission Control Module
Old Apr 6, 2012 | 10:39 AM
coolx's Avatar
Default Transmission Control Module
I need a new TCM, anybody have any information on how I could get my hands on one? Any suggestions would be apreciated - thanx
Old Apr 6, 2012 | 02:35 PM
coolx's Avatar
Default Re: Transmission Control Module
SERIOUSLY?? Nobody has any info on the transmission control module??
Old Apr 6, 2012 | 05:06 PM
BLACKSRT-6's Avatar
I have one for a SRT-6, try MrMopar he may have one for a limited.
Old Apr 6, 2012 | 05:44 PM
velociabstract's Avatar
I may want it depending on the price. I'd like to have a TCU tune but want to keep mine in case I dislike the tune. Send me a PM if your wanting to sell it.
Les
Old Apr 6, 2012 | 07:45 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Are you certain that you need a TCM or do you really need the Conductor Plate? I believe the one below is for the SRT6 :
http://volkstoymotorsports.com/Merce...1-P388842.aspx
Old Apr 6, 2012 | 08:53 PM
ImportLabSRT's Avatar
I have a good (previously installed) conductor plate and CHA connector that I will sell cheap. I replaced them thinking they were bad and it was the EGS (trans control unit).
Old Apr 6, 2012 | 09:27 PM
coolx's Avatar
Mercedes Benz Transmission Conductor Plate 1402701161 - Volkstoy Motorsports
According to the info I read on the forum, the problem I am having is a bad TCM, the fix was replacing it. I have a dronning, shuttering sensation between 20 and 30 miles per hour, the same as the other fella I read about. He had a heck of a time getting it diagnosed, and finally, after checking Mercedes and Chrysler dealers the mechanics finally figured it was the TCM. They replaced it and the problem was solved. question: is the TCM and the TCU the same component?
Old Apr 6, 2012 | 10:18 PM
Yes... to proper Mercedes/Siemens name for it is EGS.
Old Apr 7, 2012 | 08:56 AM
The TCU/TCM is simple to replace compared to the Conductor Plate. The TCU/TCM is mounted on a aluminum plate located on the passenger side footwell under the carpet. 15 minutes, a 10mm wrench and some side cutter pliers for removing two zipties. It would be perfect if you could find someone in your area to try their TCM to see if it really is the cause of your issue. Just a thought.
Also, try MrMoPar to see if he has a TCU from an NA !!!
Good luck.
Old Apr 7, 2012 | 01:04 PM
coolx's Avatar
Good luck.
Thanx Sparkie for the suggestions
Old Apr 7, 2012 | 01:26 PM
MrMoPar's Avatar
Sorry, no NA tcm modules.
Old Apr 7, 2012 | 04:21 PM
coolx's Avatar
I know, I checked. Thank you for responding
Old Apr 7, 2012 | 04:26 PM
turbomar's Avatar
04 CHRYSLER CROSSFIRE TCU #A0335451132 | eBay
Call them before you order to ensure compatibility
Old Apr 7, 2012 | 04:43 PM
HA, "reprogramming may be needed, check with a dealer". Good luck finding a dealer that knows or cares.
Old Apr 7, 2012 | 04:44 PM
coolx's Avatar
Thanx Turbomar, I just called and it went to voicemail, I left him a message. Hopefully this is what I need. Thanx again
Old Apr 7, 2012 | 11:32 PM
coolx's Avatar
ZERACER - you are right, I talked to the ebay seller and he told me it would need to be programmed or it would not work...
I wish tighed1 would chime in on this, from what I've read in other threads, he's got some hands-on experience with the TCM...
Old Apr 8, 2012 | 07:25 AM
32krazy!'s Avatar
i have the fix for you!! i bought an ebay tcu that had all the proper # and when i installed it guess what ? limp mode!! turns out many tcu's are the same but the files installed are different for the car its used on. in my instance i needed the slk32 file and the tcu was programmed for the slk320. sooo off to speedriven the tcu went and marcin flashed the proper files onto the tcu for 100$. total cost for the tcu to work properly was 235$ shipped and new the cost was 883$!!!
so get the proper tcu and ship it to marcin and you can save hundreds
Old Apr 8, 2012 | 09:41 AM
MurderedXF's Avatar
I have a tcm that is in working order, ill sell to you for $70 if interested let me know via PM
Happy easter
-Jason
Old Apr 8, 2012 | 09:55 AM
Happy easter
-Jason
A great deal for coolx. I'm sure you'll be hearing from him.
What a great forum this is!!
Old Apr 8, 2012 | 01:48 PM
coolx's Avatar
Hey 32, this sounds interesting...tell me more about this "speedriven" And by the way, thank you for your response - all you guys on the forum are model citizens!
