Dashdaq user input ground wiring? Need urgent help
Old Jul 23, 2012 | 03:00 AM
Silverarrow's Avatar
Default Dashdaq user input ground wiring? Need urgent help
Hi!
I have connected everything for the DashDaq and Zeitronix ZT-2 but I don't know how to connect the User Input wiring. I know that green wire is a +5v sensor input but where should the ground go from the sensor??
Is it possible to connect the brown cable from the zeitronix? That is I use the +5volt input in the dashdaq but the ground is not connected to the ground on the Dashdaq it is instead connected to the ground on the Zt-2.
If this is not ok, where should I connect the ground on the dashdaq, black or brown??
Need help fast, please
Old Jul 23, 2012 | 05:43 AM
32krazy!'s Avatar
Default Re: Dashdaq user input ground wiring? Need urgent help
the power for the dashdaq is supplied by the obdII cable . no other hookup is needed.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Reliableron
Oct 17, 2015 10:19 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Sep 28, 2015 07:40 PM
81's
Sep 13, 2015 04:34 PM
