Reset Needed??? for working with the ignition module?
Old Aug 12, 2012 | 09:46 PM
mysilverbullet's Avatar
Default Reset Needed??? for working with the ignition module?
Hello!
I have been having problems with the key not turning over due to the steering wheel locking up. So thanks to some posts on here I've decided to either change out the ignition module or just grind down the locking pin myself.
The process looks pretty simple. My one concern is that if i disconnect the battery or pull the connection on the ignition module, am I going to need a computer reset (not sure on the terminology on this but have heard that it needs to be done in some cases).
Any info on this would be VERY helpful. In addition to my original question, when is a reset needed??
Thanks in advance.
Old Aug 12, 2012 | 10:50 PM
itsky's Avatar
Default Re: Reset Needed??? for working with the ignition module?
As far as disconnecting the battery, the only thing you will probably loose is the memory settings in your radio. Car should run fine otherwise.
autumnmass
Jul 2, 2015 10:35 PM
TropiGal
Jun 25, 2015 08:45 AM
Jacksung
Jun 23, 2015 04:28 PM
WindRestrictor
Jun 16, 2015 12:18 PM
WindRestrictor
Jun 1, 2015 02:31 PM
