PLEASE HELP...START ISSUE!!! ECM? RCM? Skreem?
Old Aug 3, 2013 | 01:09 PM
Mrmiata's Avatar
Default Re: PLEASE HELP...START ISSUE!!!! ECM? RCM? Skreem?
Originally Posted by stlouistrucker
I've discovered that I only have a problem if I use the recirculate air button after turning off the car. I find it strange that I'm just now having the problem since I've been using that feature when running the AC for five or six summers. My brother thinks I need to drive further to recharge the battery or buy a battery tender. I drive the car every day but for short distances. With a good battery and good alternator how far should one have to drive (no more than 40 mph) to recharge the battery after starting it when using the radio, AC and recirculate feature?
My understanding is the recirculating air system is supposed to shut off if voltage is low...
My thoughts would be check and clean your battery terminals.. and follow the ground wire to it's connection and clean it. Users have found that to be an issue on occasion.
Old Aug 3, 2013 | 02:02 PM
My suggestion is to check the battery voltage, when idle, when ticking over and when driving. When driving check to see if the voltage on a digital volt meter plugged into the cigarette lighter outlet goes down after putting on a few miles.
These meters can be purchased from Walmart and other places for a couple of bucks. Worth the investment.
See Pizzaguy's post on this matter.
Old Aug 3, 2013 | 02:07 PM
Mrmiata's Avatar
I also have the automatic and yes it was taking an "extra second or two" to fire when cranking. After jumping it this afternoon, I took it to Advance Auto where I had bought the battery. They had me turn it off so they could check the battery. They said it was a little low on charge but the battery was good. He then asked me start it up so that he could check the alternator. It started instantaneously. He also said that the alternator checked good. He said there must be something draining the battery. Can the RCM problem cause the battery to drain?
Basis for my response, but It never hurts to double check these things.
Old Sep 21, 2013 | 11:13 AM
figment's Avatar
I have found that my 06 crossfire wont start, even though all electrics work there is a ground wire that is not making a good connection. haven't had time to trace it yet but when i punch the black wiring box in the engine compartment on the passenger's side it starts.
Old Sep 21, 2013 | 11:34 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Then you need to start right here: https://www.crossfireforum.org/forum...tml#post430634
Bob4kacz
Sep 16, 2015 11:20 AM
81's
Sep 13, 2015 04:34 PM
bobbie
Sep 12, 2015 12:49 PM
Melspank
Sep 9, 2015 08:02 AM
MickeyNasty
Sep 6, 2015 08:29 PM
