Service Code?
Old May 22, 2014 | 06:36 PM
srtmodder's Avatar
Default Service Code?
So when I start up my car the first couple of seconds the dash displays the 2 wrenches and the number 600. After driving more today now it has the two wrenches and the number 500. What does this mean? I just had the crankshaft position sensor replaced so didn't think it could be part of that.. Any ideas?
I tried searching but everything came up taking me to random links. Any help is greatly appreciated. Heading out of town and need to get it fixed if it is very important.
Thanks!
Old May 22, 2014 | 07:25 PM
Default Re: Service Code?
It means you need to perform service 500 miles from now
It will continue to count down as you continue to put miles on the car
This is the suggested service for double wrench display
Double Wrench Service---------------------
Change engine oil, engine oil filter and rotate tires.
Replace dust filter
Lubricate hood hinges, latch and secondary latch.
Reset FSS Display
Check horn, hazard warning flashers, turn signals, indicator lamps, exterior lighting and headlamps (adjust headlight aim, if necessary)
Check windshield wipers and washer system. Replace wiper blades if necessary.
Check seat belts for damage and proper function.
Check hydraulic brakes and parking brake function.
Check fluid levels for hydraulic brake system, power steering system, windshield wiper system and engine cooling system (check corrosion inhibitor/antifreeze).
Inspect front and rear brake pads for lining thickness
Inspect tires for damage, general condition and inflation pressure. Correct if necessary.
Inspect major underbody and underhood components for leakage or damage. (If leakage is found, determine cause and repair)
Inspect condition of front axle ball joints and rubber boots.
Inspect condition of steering components and rubber boots.
Inspect condition of accessory drive belt.
Inspect body for paint damage (every 2 years)
Check chassis and supporting body parts for damage and corrosion (every 2 years)
Retighten steering locking bolts (50,000 miles or 4 years)
Check condition of driveshaft flex discs (50,000 miles or 4 years)
Replace fuel filter and air cleaner filter element (60,000 miles or 4 years)
Change the automatic transmission fluid and filter (80,000 miles). After this changes it is filled for life. Manual transmission comes filled for life from factory.
Replace spark plugs. (100,000 miles or 5 years)
Replace engine coolant using extended life coolant (100,000 miles or 5 years).
Old May 22, 2014 | 07:32 PM
To reset the miles to next service back to 7000 and clear the wrenches follow this procedure exactly as it says
You might need to try it a couple of times to get it to reset but it will
RESETTING THE FSS MAINTENANCE INDICATOR AFTER AN OIL CHANGE / Service etc.
1) Move the ignition switch to the “RUN” position
2) Within 4 seconds of moving the ignition switch into the
“RUN” position, press the reset button for the trip odometer
twice within one second The display for the FSS service
request is activated for 10 seconds
3) During the 10 seconds the FSS service request is displayed,
move the ignition switch to the “OFF” position
The FSS service request will continue to be displayed
4) Press the reset button for the trip odometer and
hold
5) Move the ignition switch to the “RUN” position
6) Continue to press and hold the reset button for the trip
odometer (about 10 seconds) until the audible signal
sounds and the new start distance appears in the display
The tool symbol should disappear at this time
Old May 25, 2014 | 04:46 AM
srtmodder's Avatar
Thank you very much! I will be doing this tomorrow!
TOPLESS
Feb 9, 2016 11:28 AM
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Abaton6
Sep 24, 2015 10:14 PM
MickeyNasty
Sep 6, 2015 08:29 PM
