clicking in the rear end
Old May 24, 2014 | 07:39 AM
RED DOG's Avatar
Default Re: clicking in the rear end
Originally Posted by rcompart
With the new wheels, the length of both that was threaded through the hub was greater than with the stock wheels and you most certainly damaged the parking brake components. The reason they are not making as much noise now is it's just the the stuff is just bouncing around off the side of the drum vs being continuously struck with the extra length of the lug bolts.
Sorry to not have better news for you.
You'll need to remove the rear rotors and determin what parts are damaged. You could be lucky and only need to buy new shoes but I'm guessing you're gonna need more than that. To remove the rotor, you will need to remove the calipers as well but you can do so without disconnecting anything, just remove the bolts, wiggle the caliper off the rotor, remove the torx bolt that is holding the rotor onto the hub and start looking at what's going on behind the hub.
Yes . . . exactly what he said . . .
AND ALSO
Originally Posted by JEFASOLD
Also make sure you have the correct bolt seating shape for your wheels. There is conical and ball types.
or you'll create another problem with those new wheels . . .
Originally Posted by austinbarrylee
warranty coverage. do you all think its covered under. thanks
Warranty doesn't usually cover this type of problem . . . Learn BEFORE you do!
Old May 24, 2014 | 03:28 PM
austinbarrylee's Avatar
I pulled the caliber off today. 2 springs on each side came out.
Old May 24, 2014 | 05:15 PM
Looks like this can be easily remedied with a trip to a scrap yard that has a Crossfire, and some shorter wheel bolts next time.
Old May 26, 2014 | 12:17 AM
rcompart's Avatar
It would appear you need two pull-back springs (A 201 423 06 92) and while you're replacing them, I'd pick up and replace the four extension springs (A 201 423 05 92) that hold the brake shoes to the backing plate as well since it looks like the lug bolts got ahold of them too.
amx1397
Jan 24, 2016 02:12 PM
stlas69
Sep 3, 2015 10:28 AM
Just1n
Aug 8, 2015 11:45 PM
BrenLW
Aug 5, 2015 04:53 AM
FIXRE
Jul 9, 2015 09:16 PM
