Central locking not functional
Old Sep 17, 2014 | 02:51 PM
Default Re: Central locking not functional
Originally Posted by RED DOG
That's a good question. I don't know but I suspect you may need to send a child into the rear area to pull that emergency hatch release wire ? ? ? OR try to grab it with a pole type tool and pull it.
There's a wire? Not on my coupe.
Old Sep 17, 2014 | 03:17 PM
goodgenes79's Avatar
I had a similar problem, when something in the circuit would blow the fuse. My key remotes wouldn't lock the doors, however the button on the dash would unlock. You might try that just to see. My problem was the security alarm is on the same circuit and something fried it and burns the fuse once the key is turned on. Cutting the wire was my only solution for now. Anyway, try the button as it is on a different circuit as the key remote system. otherwise emergency latch is only option.
Old Sep 17, 2014 | 07:04 PM
RED DOG's Avatar
Oppps! My coupe is parked over at another property so I didn't get a chance to look at it. Now that I stop and think about it I should have known the coupe doesn't have an emergency inside release (I've taken that whole area apart and reassembled it. Just blame it on having a senior moment. Sorry for that faulty advice . . .
Old Sep 17, 2014 | 07:11 PM
I get those moments all the time.
Mackel
Oct 16, 2015 09:03 AM
Selbyl
Sep 26, 2015 04:15 AM
smokey847
Sep 15, 2015 10:47 AM
xjken
Sep 13, 2015 10:18 PM
crmnal
Sep 6, 2015 08:07 AM
