run away starter
Old Aug 2, 2014 | 10:30 AM
Cptironjackcash's Avatar
Default run away starter
Hey guys, I've looked and not see this yet. so heres the story.
Drove 30 miles all fine, stopped for 10 mins then drove 3 miles, car died. on trying to restart, starter engages with key in ON position, no attempt to run, no longer need clutch to make starter engage and when you turn the key on the radio comes on with the starter.
Ok lot of things happend at once. I've exposed the ignition modual the switch is dash mounted but it goes into the steering colum from there. I've changed crank sensor just because, batt is good enough to move the car in 1st gear. But the runaway starter and the radio coming on is tossing me a curve
Jess
Old Aug 3, 2014 | 10:19 AM
Default Re: run away starter
Jess
I'm guessing a stuck starter solenoid.
Old Aug 3, 2014 | 02:37 PM
Car died with switch on. So, I would think it would burn the starter up in that case. On re-start, you turned the key back on, and starter engaged with or without the clutch disengaged? And, the radio turned on? Isn't there a safety switch on the clutch arm, that doesn't allow the starter to engage unless the clutch is disengaged? I don't own a clutch/stick XF, but I would think it would have one of these. This certainly wouldn't explain it dying or the radio coming on though. First time hearing of this problem. But if that switch does exist and it shorted, maybe...???
Old Aug 3, 2014 | 02:54 PM
THen it would crank continously without the key. (Page 8W-20-2 - assuming the manual is accurate, that is.)
The only explanation (AGAIN, assuming the manual is accurate) is that the key switch itself is bad, but that STILL does not explain that it cranks without pushing the clutch pedal.
Old Aug 3, 2014 | 03:34 PM
I just looked at the circuit diagram and agree.
Suppose the clutch interlock switch failed some time back and you had not noticed that you did not need to push in the clutch pedal, and then the iggy switch shorted out in the ON position when the problem started?
The radio would come on and the short would turn the starter.
amx1397
Oct 2, 2015 05:20 PM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
WindRestrictor
Sep 18, 2015 05:10 PM
tritongreen
Sep 18, 2015 07:32 AM
Valk
Sep 17, 2015 11:43 AM
