2006 Crossfire Will Not Start
Old Aug 31, 2014 | 11:03 PM
nid4u's Avatar
Unhappy 2006 Crossfire Will Not Start
Friday night, I came home, parked the car in the garage. Sunday morning I went to start the car. At first, I noticed that the automatic door locks did not work. I had to manually open the door. Then I went to start the car. The car started and abruptly stalled. I tried again, but the engine would not turn. The battery is good. I figure it might be the fuel line, maybe the fuel filter is dirty. Or the starter or solenoid. I went to check the fuse and when I opened the fuse panel door on the driver side, the alarm went off. Any thoughts?
Old Aug 31, 2014 | 11:25 PM
green24u's Avatar
Default Re: 2006 Crossfire Will Not Start
Sounds like the mystery no start. Most likely a RCM going bad. Do a search on Mystery No Start. A quick fix is to unhook the neg battery terminal, wait a few minutes for the system to reset, hook neg terminal back on, start car. Good Luck!
Old Sep 1, 2014 | 12:36 AM
nid4u's Avatar
Thank you! i'll try that in the morning and let you know what happens. John
Old Sep 1, 2014 | 03:24 PM
skreem module is another possibility to read up on.. that is unhooking the battery and you will only get a few restarts. The RCM has solder joints that get hot, and disconnect killing the car. Once those joints cool and make contact, the car will start. Sooner or later, it will not make connection and it will not start... Both are known problems you can research here.
Old Sep 1, 2014 | 04:27 PM
You say the engine would not turn, I take it you mean it does not do crank over at all? Do you hear the starter click or any noise at all ....?
roland1226
Feb 26, 2019 10:19 PM
racingagent
Jun 8, 2015 07:29 PM
gobraves423
Jun 6, 2015 07:03 PM
Ephr8a
Jun 4, 2015 12:42 PM
texex91
Nov 20, 2003 06:00 PM
