No Fuel To injectors '83 Camaro Tried ...
Old Oct 2, 2014 | 02:05 PM
samcrow76's Avatar
Default No Fuel To injectors '83 Camaro Tried ...
Hi there, first forum I've ever joined. I'm at a loss.
1983 Camaro 5.0 Cross Fire Injection no fuel to injectors.
I've in order:
checked relays and fuses fuell pump, Inj #1 and #2.. all the fuses
Replaced fuel pump and filter sock and fuel filter
have 13-14psi fuel pressure
replaced HEI module
replaced ECM
Traced wiring for a bad ground.
Still no fuel to injectors
please help me.
Old Oct 17, 2014 | 10:35 PM
blackpepper's Avatar
Default Re: No Fuel To injectors 83 Camaro Tried ...
Not trying to be rude but this is a crossfire forum not a camaro forum you probably wont get much help here.
Old Oct 18, 2014 | 12:02 PM
samcrow76's Avatar
Thanks for the info. 83 Camaro with crossfire here.
running well now, set idling back to factory but having trouble when driving, it's stalling when stopped or when you give it gas to accelerate .... if you take it real easy it's fine.
Any help would be appreciated
Thank you
Old Oct 18, 2014 | 12:19 PM
Thank you
This is a Crossfire CAR forum ( The Chrysler C-R-O-S-S-F-I-R-E, 2005-2008 ), not a cross-fire injection forum. As suggested above, maybe try this on a Corvette forum ?
We have the Mercedes Benx M112 V6 engine, and while also fuel injected, it has NO relation to the 5.0 Chevy V8.
See picture below .........
Old Oct 18, 2014 | 12:49 PM
please help me.
Without looking in a manual, most GM throttle body injectors require 25-40 psi to operate properly.
Old Oct 19, 2014 | 04:33 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Thank you
Damn Canadians........hopefully he lives near 180....He'll get it going.
Old Oct 19, 2014 | 05:56 PM
Default Re: No Fuel To injectors '83 Camaro Tried ...
LMAO............I had a '92 Camaro w/ Crossfire injection, so I knew he was in the wrong house, but I did point that out and still tried help a car guy out.....
rmcdaniel12
Nov 4, 2015 04:08 PM
o55ie18
Oct 5, 2015 05:50 PM
Oct 1, 2015 01:42 AM
Sep 25, 2015 02:16 AM
04Fire
Sep 15, 2015 07:40 PM
