Mysterious clap
Old Oct 20, 2014 | 09:58 AM
BEATv1's Avatar
Default Mysterious clap
Hello,
this problem occurred maybe within the last 100 miles. whenever im in gear and disengage on the clutch, i hear a clap sound. it ONLY sounds in the rear driver side like something is stuck to the wheel well and hitting against a plastic/metal part. when i depress the clutch all the way is disappears and only when i let go it starts again and in gear. i looked underneath and didnt see anything wrong with the suspension or brakes so im leaning towards the transmission. i know it's a little vague but any ideas may help. thanks!
Old Oct 20, 2014 | 04:20 PM
Default Re: Mysterious clap
you need to get under the car, on a car lift would be great, and look at the area where the shock mount is at the body. If not a shock mount, then look at the drive shaft flex discs.
Old Oct 20, 2014 | 04:58 PM
BEATv1's Avatar
thanks for the response, ill check that out this weekend when i get some free time. its just weird because once i let go of the clutch the rattling appears. when driving normally and on highways, going over bumps wont trigger it. only when i'm below 40mph and drop the clutch and maybe under heavy braking.
Old Oct 20, 2014 | 08:16 PM
You could have a clutch plate bad as well. A broken spring on the plate. Just have to eliminate one thing at a time....
Old Oct 25, 2014 | 11:23 PM
Have someone stand next to the rear wheel on the side where the click is coming from, if the brake pad has broken loose it will sound like a clap, if you just had your brakes done then they or you installed the wrong size brake pads, a test would be to pull the e brake and see it it claps . jim
Old Oct 28, 2014 | 09:41 AM
BEATv1's Avatar
interesting. this intrigues me because when i bought the car (probably 2 months now) the person gave me the receipt for rear brake pads and rotors that was installed like 2 days prior to me buying. i'm unclear as to the test but i will try to drive with the e brake all the way up? or semi? it there an easy way to see if my brake pads are the wrong size? i'll search for installing brake pads and sizing.
thanks
Old Oct 28, 2014 | 01:17 PM
you can open the door lean slightly out and move forward hit the brakes,,,now do the same thing in reverse if they are wrong u will here a click or maybe a clap, jim
northwest_crossfire
May 30, 2016 05:19 PM
Steven 4190
Nov 25, 2015 10:12 AM
StanTheEdge
Sep 2, 2015 12:05 AM
Steven 4190
Aug 15, 2015 10:35 PM
SuperD500
Jul 23, 2015 02:53 PM
