Transmission sticking after WOT (Auto)
Old Oct 31, 2014 | 01:02 AM
Mr5150's Avatar
Default Transmission sticking after WOT (Auto)
New Srt6 owner. Sometimes after WOT the car wants to stay in 3rd or 4th. Cant really get it to replicate.
Also the car idles pretty rough. Very noticeable while in gear but stopped for periods of time.
And the IC pump is dead. Have a new one on the way...
Did I get a lemon?
Old Oct 31, 2014 | 08:31 AM
Default Re: Transmission sticking after WOT(Auto)
Where in Alabama ?
I'm in Lineville.
Have you checked the fluid level in the transmission ?
Rough idle often points to vacuum leak(s).
Old Oct 31, 2014 | 09:10 AM
Mr5150's Avatar
Just right down the road in dadeville. Have not checked the trans fluid. Probably shouldve started there lol
Old Oct 31, 2014 | 07:23 PM
Default Re: Transmission sticking after WOT (Auto)
If you were having pump problems, I would wait and see if the new pump straightens out your tranny problems. When the S/C is kicking in and out, like that it tends to confuse the tranny as well.....It is the same thing for those who launch full throttle then back off suddenly, and the tranny won't shift because it thinks you want to go all out.....
Old Oct 31, 2014 | 09:36 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Not sticking. Tranny is working as it should. The tranny holds the gear thinking you are decelerating. Give it a little more gas and it will change up a gear.
syfi
Mar 28, 2026 04:14 PM
Sterling57
Apr 11, 2016 06:11 PM
Oct 1, 2015 01:42 AM
Dementors
Sep 30, 2015 07:46 PM
rfourt
Sep 25, 2015 01:38 PM
