Crankshaft issue?
Some description of the noise would be helpful. I would release the tension on the belt, then grab it and wiggle it to see if it is loose.
You can also eyeball it and see if the serpentine belt looks like it is in proper alignment with all the other pulleys and idlers.
There have been some cases of the crankshaft pulley getting loose and even falling off.
Not good - that's a lot of spinning mass to have running loose in the engine compartment, not to mention the loss of power steering, alternator and water pump.
IF IT'S LOOSE, DON'T DRIVE THE CAR !!!!
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
bobbie
Sep 12, 2015 12:49 PM
