Idles rough, No throttle
Old Jan 11, 2015 | 07:35 PM
JSK's Avatar
JSK
Default Idles rough, No throttle
05 SRT drove it to work recently and on the way home had a hard time getting it to start and keep running. When it would run the idle was terribly rough, babying the throttle I could get under way but if I tried to actually accelerate the motor would die. I could wait a bit and get it to restart and it would idle rough and not take throttle all over again. I'm a pretty patient guy and made my half hour drive home in about two hours. It seemed the symptoms were much like a bad CPS but not exactly. Installed a new Bosch CPS today and still have the exact same problems. Hard start, rough idle which will smooth out above 1500 RPMs but dies or drops back to the 800 RPM rough idle with depressing the throttle. Also have
no current codes. Car has 13,000+ miles. Looking for some ideas.
Jeff K
Old Jan 11, 2015 | 09:14 PM
Padgett's Avatar
Default Re: Idles rough, No throttle
Sounds like bad coil or shorting plug wire(s). Secondary ignition won't set codes but mis/no fire should give a P030x. Any smoke out the pipes ? Have seen a coolant sensor reading too low flood an engine.
Old Jan 11, 2015 | 11:07 PM
04Fire's Avatar
Any codes???
Old Jan 11, 2015 | 11:39 PM
JSK's Avatar
JSK
There are no codes.
Old Jan 12, 2015 | 12:30 AM
ChrisA's Avatar
K40 the relay https://www.google.com/search?redir_...l=en&q=slk+k40 in the fuse block. Bad solder joints
Had a slk not sure what they call it here but same part. Causes all kinds of problem's
google slk k40
Old Jan 19, 2015 | 06:46 PM
JSK's Avatar
JSK
So after changing the CPS with no improvement I pulled the RCM and sent it to DJ. He repaired it and turned it around right away and I installed it yesterday. Haven't been out on the road yet but it started right up and ran fine. I'm thinking it's fixed.
Jeff K
Old Jan 27, 2015 | 06:01 PM
04Fire's Avatar
Good to hear!
rampntlion
21
Feb 11, 2019 08:18 AM
crossfireusa
Oct 28, 2015 12:03 AM
blackpepper
Racing
16
Sep 27, 2015 01:38 AM
atdavis2
Sep 21, 2015 01:25 PM
steps
Sep 3, 2015 07:24 PM
