Loose pulley?
Old Jan 23, 2015 | 01:43 PM
birdxofxprey's Avatar
Default Loose pulley?
The large pulley in the center moves in and out (about a quarter inch) while the engine is running and makes a clicking noise. About the same time this started happening, the battery failed to hold a charge and the engine overheated. I'm assuming the belt is not functioning properly because of this loose pulley, thus causing the other problems.
Is this a routine repair - or does it require an "authorized" dealer?
Any advice appreciated!
Old Jan 23, 2015 | 04:16 PM
RED DOG's Avatar
Default Re: Loose pulley?
That's your water pump going bad. Get it fixed immediately! That would have nothing to do with your battery failing to hold a charge though. Get a new water pump installed and then see what's next to do.
Old Jan 23, 2015 | 04:19 PM
EDIT: If as Bob says above it is the black steel pulley that the belt runs over with the non-grooved side, then ignore all I said below .....
STOP NOW !!!
DO NOT PASS GO !!!
That is the crankshaft pulley ( or harmonic balancer )
If it comes off, all sorts of bad things can happen.
You will need to find a good MB repair shop that can work on a SLK320 and get it hauled to them,
or fix it yourself. ( This would require a new bolt, possibly a new woodruff key and a HUGE torque wrench,
not to mention the special tool for locking the flywheel )
Old Jan 23, 2015 | 04:32 PM
Thanks guys!
rmcdaniel12
Nov 4, 2015 04:08 PM
4drturbo
Oct 2, 2015 12:58 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
Sep 26, 2015 10:21 PM
