overheating problem
Old Mar 22, 2015 | 07:46 PM
garys383's Avatar
Default overheating problem
hi all i hope someone can give me some advice. my wifes 05 crossfire with a 3.2l sohc used a lot 2gal of coolant over the last 2 wks. there are no obvious leaks anywhere or wet spots under the car. the low coolant light came on every other day. i drove it yesterday for about 30 min and it overheated and popped the upper rad hose at the plastic fitting in the middle of the hose. i replaced the thermostat and repaired the hose with a worm clamp, fail...lasted about 30 min again. anybody have any idea where the water has been going in the first place? thanks for any help
Old Mar 22, 2015 | 10:59 PM
Default Re: overheating problem
I hate to even think about this but have you checked for the fluid leaking into your engine oil?
How many miles on that car?
Maybe the water pump has lost the impeller that circulates the coolant.
Any plastic bag or something caught against the radiator?
Old Mar 23, 2015 | 06:48 AM
Speedy4x4's Avatar
Default
Or is there excessive moisture coming out exhaust?
Old Mar 23, 2015 | 08:09 AM
Pull the engine oil dipstick.
If it looks gray, or is not 100% engine oil, then you have a serious problem.
Could be as simple as a blown head gasket, and you MAY be able to salvage the engine.
I hate to be a downer, but if 2 gallons of water/antifreeze have been going through the engine for 2 weeks, I don't hold out much hope for it.
Old Mar 24, 2015 | 08:14 PM
garys383's Avatar
im hopeful it only has 65k on it. im off on thur so will drain the oil with my fingers crossed...wish me luck
Old Mar 24, 2015 | 08:52 PM
velociabstract's Avatar
Check the dipstick. If you see foam or a milky color the antifreeze is getting into the oil. If your popping the radiator hose off the cooling system, perhaps it's being pressurized by the engine i.e. head gasket leak. But don't waste time or money, pull the dipstick and look.
Les
tcar32909
Aug 1, 2024 02:41 PM
eikon
Sep 9, 2019 10:16 PM
jimf
Oct 10, 2015 10:22 AM
Abaton6
Sep 24, 2015 10:14 PM
Den656
Sep 23, 2015 12:27 PM
