Bad front caster
Old Apr 19, 2015 | 05:48 PM
funnybunchofitalians's Avatar
Default Bad front caster
Hi all,
This is a spin off thread from my previous thread[https://www.crossfireforum.org/forum...rear-toe.html] about bad rear toe (similar to how "Better Call Saul" is a spin off from "Breaking Bad").
It seem like the previous owner of my car(purchased recently) hit a pothole with both fron left and rear left wheels. First and most obvious effect was the bent rear toe link that is now fixed.
However, there is a further problem - bad front left caster (as seen in the picture).
The guy that worked on my car said that the control arms didn't look visibly damaged. Therefore, the reason for the bad caster could be literally anything...
Can you guys help me narrow down to some plausible possibilities so that I don't end up fixing wrong things?
Old Dec 3, 2015 | 03:03 PM
Default Re: Bad front caster
After many long months this issue finally got resolved. Turns out it was a bad control arm. $1000 later the car goes straight and looks perfect.
PNA
Nov 12, 2020 04:44 PM
xfireohio
Jul 20, 2020 12:03 AM
cdcrone123
27
Sep 24, 2015 11:28 AM
cdcrone123
Aug 4, 2015 06:37 PM
UNDER PSI
Jul 18, 2015 02:12 PM
