Pulling the steering wheel.
Old Aug 19, 2015 | 10:22 AM
zj93i6's Avatar
Question Pulling the steering wheel.
Has any one tried this ? Are special tools required ?
Old Aug 19, 2015 | 02:19 PM
Default Re: Pulling the steering wheel.
No special tools, but you must use only a T30 Torx bit to undo the screws holding the wheel on.
Others have used T27, that is the quick way to ruin the head of the screws and give yourself a real pain in the butt.
Disconnect the battery first as you will have to remove the air bag. Apart from that it is easy enough.
Old Aug 19, 2015 | 02:48 PM
Warning : Do not reconnect the battery until you have the air bag re-installed or the entire SRS will be disabled
and you will have to find a dealer that can re-enable it !!!!!!!!
Old Aug 19, 2015 | 05:03 PM
RED DOG's Avatar
That's RIGHT . . . Ask me how I know that!
Old Aug 19, 2015 | 10:05 PM
turbomar's Avatar
T30 to undo the 2 airbag screws. Allen socket to remove the tapered cap screw holding the steering wheel, I believe it's 10mm. Take note of the alignmen marks before removing steering wheel
Mackel
Sep 29, 2015 02:41 PM
livefreeordie
Sep 22, 2015 08:13 PM
cdcrone123
Sep 20, 2015 10:02 PM
bbsrt6
Sep 19, 2015 11:21 AM
tritongreen
Sep 18, 2015 07:32 AM
