Head Beam / Flash light don't work - both of them
Old Nov 19, 2015 | 02:55 AM
Mr G's Avatar
Question Head Beam / Flash light don't work - both of them
Have checked the fuses - and bulp lights. Please help. Normal light works fine
Old Nov 19, 2015 | 07:01 AM
Default Re: Head Beam / Flash light dont work - both of them
Most likely a bad 'flash to pass' switch in the stalk.
Old Nov 19, 2015 | 07:18 AM
Mr G's Avatar
You mean a bad wire to both lights - What does stalk mean?
Old Nov 19, 2015 | 08:12 AM
O, Denmark, sorry.
Stalk is the thing that you press forward for high beams and pull back for "flash to pass".
NOT a bad wire to both lights, there is a switch in the stalk to cause the high beams to come on when the stalk is pulled toward you.
Old Nov 19, 2015 | 08:21 AM
Mr G's Avatar
Thank you. Is it also called dimmer switch?
Old Nov 19, 2015 | 08:34 AM
Mr G's Avatar
Can it be repaired or do i have to buy a new Stalk?
Old Nov 19, 2015 | 08:58 AM
That I do not know.
I have never had a stalk out to actually see the switch.
ANYONE ????
Old Nov 19, 2015 | 12:18 PM
deltacrossfirebob's Avatar
same problem
have not fixed yet
Old Feb 16, 2016 | 05:47 PM
MB04XFIRE's Avatar
I just installed some hid lights in my fogs and dims. They work great but after flicking the brights on and off a few times to see how they looked in comparison to the hid. And now the brights don't come on anymore when I put the brights on.. I flick the brights switch and the fogs and dims stay on and brights don't come on and there is no high beam light showing on the dash.. . But when I pull the switch towards me for the flash feature the brights do come on and the fogs go off as they should and the high beam light shows up on the dash.
Anybody have seen this before? Did I somehow fry the brights switch??
Any help would be great. Thanks
Old Feb 16, 2016 | 07:40 PM
It is strange that the low beams each have a 15a fuse, whereas the high beams have but a 7.5a fuse each. Go figure.
Anyway, I'd say replace both high beam 7.5a fuses ( fuse 3 & 5 in the ILCM aka headlight switch ) with 15a ones and carry on.
Old Feb 16, 2016 | 08:23 PM
MB04XFIRE's Avatar
is the flash to pass on a different circuit then the high beams? Different set of fuses? As my flash to pass works but not the constant on hgh beam position
Old Feb 17, 2016 | 05:25 PM
MB04XFIRE's Avatar
Does anyone know the part number for the multi function switch? And also the Mercedes equivalent part number? I want to find out what a new one is worth..
Old Feb 17, 2016 | 05:41 PM
MB Part# 1170 540 03 44
Chrysler Part# 05098519AA
Used price on eBay about $100
New part about $260
Old Feb 17, 2016 | 05:51 PM
MB04XFIRE's Avatar
Perfect thanks for the part numbers.. So very much appreciated..
Have yourself a great day.
Old Feb 18, 2016 | 05:39 PM
MB04XFIRE's Avatar
I just priced that multi function switch and did so at both Mercedes and Chrysler..
OneHundred80... You certainly wouldn't have won the prize on the price is right with your assumption of pricing for that multi switch lol...
Get this.. Mercedes it was $554.00 CAnadian including taxes and at Chrysler it was a whopping $804.00 Canadian dollars including taxes..
I think that if I sell my car piece by piece I could be a millionaire lol
Old Feb 18, 2016 | 06:31 PM
I use US dollars so as not to confuse the issue and
I got the price on line.CLICK I got the price on line.CLICK
If you get it in Canada you'll pay through the nose.
eBay price CLICK
Old Feb 18, 2016 | 06:40 PM
Mrmiata's Avatar
Car-Part.com--Used Auto Parts Market
Old Feb 18, 2016 | 08:20 PM
MB04XFIRE's Avatar
Default Re: Head Beam / Flash light don't work - both of them
I was only curious as to what the stealerships were going to charge.. No way in hell was I going to buy one from there....
Thanks for putting up various items for sale... I'm thinking that at the rate these things seem to burnout I should probably find a new one as opposed to a used one.. The time it will take to take everything apart and access the switch it's best I go the safe route and put in a new one.. And not take the risk of taking the time to take everything apart and have a used part fail lol
Old Feb 18, 2016 | 08:25 PM
Who says these burn out quickly? I know of two or three, reading this thread after being on this forum for a short time and assuming they burn up is not right.
Old Feb 18, 2016 | 08:39 PM
MB04XFIRE's Avatar
My motto is "do it right, do it once or don't do it at all "
So all I'm saying is that I would rather put the odds in my favor and put in a new part for only 2 hundred bucks more. I don't ever want to be replacing it again lol my time to potentially have to do the work twice is worth more than the 2 bills
