Park interlock problems
Old Dec 12, 2016 | 09:39 PM
sshistand@fuse.net's Avatar
Default Park interlock problems
Being new to the SRT6's (3 days),I have an intermittent park interlock problem. I hate to just replace things. Is it possible to pull the cover on the automatic shifter lever exposing the solenoid and still operate the vehicle? I would like to test the voltage to it from the ignition reader as well as from the brake system. At the same time I can check the adjustments I saw on your forum.
Old Dec 13, 2016 | 12:05 AM
Default Re: Park interlock problems
You can over ride the locking feature by inserting a screwdriver or something similar dowd the hole specially made for this.
It is explained in the Owners Manual in detail.
