Hey guys
Old 03-05-2017, 11:08 AM
Ulivaz316!'s Avatar
Default Hey guys
My 2008 crossfire is having problems when ever i have my head light on my left break light will stop working but when i turn it off and then back on again it works if i leave the lights off. When i have the lights on the bulb works but when i press the break the left bulb goes out comepletely then if i let it go it turns back on. I changed the bulb when someone told me my tail light was out. Any suggestions?
Old 03-05-2017, 11:25 AM
JSK's Avatar
JSK
JSK is offline
Default Re: Hey guys
You likely have an open ground to that light assembly.
Old 03-05-2017, 02:33 PM
Ulivaz316!'s Avatar
What do you recomend i should do?
Old 03-05-2017, 05:41 PM
You either have the wrong bulb in there and it is rotated 180 degrees or you just have the wrong bulb in there.
Check the bulb number, just because it fits does not mean it is correct.
It has happened before.
Old 03-06-2017, 07:30 AM
Attached is a Snip-It of the Exterior Lamps for the Crossfire. Make note that there is a warning to use only the recommended lamp bulb in the Crossfire. These cars are "persnickety" when it comes to using only recommended parts.
Old 03-06-2017, 08:03 AM
I have a 50/50 feeling that we may never hear from this guy again. Right type of question and the right age group, I hope not though. Time will tell.
Old 03-06-2017, 08:26 AM
Speedy4x4's Avatar
Default
80/20
Unless another pr
oblem comes around.
What do you mean by age group?
Old 03-06-2017, 10:26 PM
Ulivaz316!'s Avatar
Thanks o will have to see whats going on.
