Central locking won't work and lost all interior lighting
Old Nov 17, 2020 | 12:25 AM
Default Re: Central locking won't work and lost all interior lighting
The central locking pump is one of those overengineered but cheaply built components Mercedes is known for. It lies in a sump in the bottom of the boot and if there are any leaks it fills with water and fails.
If the pump fails your locks don't work and your security system goes bananas. Park lamps may go on and stay on. Interior lights may not work.
Easy repair and you can find them on E-bay for about $250 most of the time.
I sealed mine up in aplastic bag and pulled the black rubber stopper out of the sump. No more issues.
Old Nov 17, 2020 | 02:45 PM
Originally Posted by fjcap1028
On my 2008 fuse 9 is for the control unit air bag. Fuse 13 is for roof light,horn,alarm,trunk light and tire pressure. Both are ok. I keep seeing articles about the central locking pump located in the trunk?
IF it hasn't been submerged in water yet (or the other module there as well), poke a hole in both of those rubber (factory) plugs rearward of the axle/diff where a "trunk" would be. That lower cavity below the rug under the Styrofoam is one of the most often happenings with flooding when a leak starts. Poking a hole in them rubber plugs drains any water before it gets high enough to soak the electronics/pneumatics located there. Good luck!
