Numbers stamped inside gas cap?
Old Dec 4, 2017 | 08:48 AM
copperfieldkid's Avatar
Default Numbers stamped inside gas cap?
Can anyone explain the two numbers stamped inside the gas cap. I have viewed two caps and each has a different set of the two numbers. Mine is 06 and 04 Another cap has 10 and 04
Here is a close up photo for reference. This should generate some thought processes !
Old Dec 4, 2017 | 08:58 AM
Default Re: Numbers stamped inside gas cap?
Most likely the month and year of manufacture.
Old Dec 4, 2017 | 09:03 AM
I just saw your PM as I was about to answer this question.
Most parts have a date stamp or batch number on them for quality control and recall purposes. I would guess that that is what these numbers are. My car is an '05 made in '04 and the numbers on it are 05 and 03. Parts also have a number identifying the tool and often the cavity or section of the tool they were made in.
Old Dec 4, 2017 | 09:05 AM
"..Most likely the month and year of manufacture..."
Perhaps for the cap itself, but NOT the vehicle. My car 's date of MFG is 09/04 with a MDH 091020
THANKS 180, edited so as to add my response to both of you
