Central locking not working collective effort?
Old Jan 27, 2018 | 04:40 PM
Default Re: Central locking not working collective effort?
Originally Posted by Padgett
Well just one fob makes it harder. Have you tried holding the fob inches from the car and moving all around the car while clicking. Could be an antenna issue & not sure exactly where the antenna is in yours.
You tell me where you antenna is and I’ll tell you where his is, sound fair?
Old Feb 8, 2018 | 01:46 PM
Lyndond's Avatar
thank again for the replies.
sorry I've been quiet for a while.
I finally had time to check if my fob was sending a signal today with a local locksmith.
My key IS sending a signal which is good news. but i guess the bad news is its looking more like its the skereem or the bcm.
I will also check out that relay first in a last ditch hope its something cheap.
I will update when i have more news
Old Aug 12, 2020 | 02:31 PM
Probably the pump got wet in the trunk, if it is a roadster.
Old Aug 12, 2020 | 02:34 PM
If that is dry, re syncronize your key FOP, Tpye it into the searck, top R/H portion of the page.
Old Aug 13, 2020 | 09:17 AM
Lyndond's Avatar
Originally Posted by crevine1
I have the same exact issue, so what was the solution, the BCM??
I gave up in the end, it was either the skreem unit or the bcm. I didn't investigate any further as both exceeded the money I wanted to spend on the car.
They key was sending the signal it just wasn't being received by the car. The pump in the boot was fine as every worked from the dash switch which I confirmed by visual inspection. The skreem has to be a codes one using your vin number. And there were mixed opinions as to if the bcm needed to be a vin match or just the exact part number.
Hope this helps, good luck. If you do ifnd out what it was please update the thread to help future owners
Old Aug 14, 2020 | 04:44 AM
Viper-666's Avatar
In Germany I have had a crossfire who has the same issue, there it was a connection problem on a plug. The skreem sends the open/close command over a serial connection (wire) to the bcm and the bcm over CAN to the locking pump in the trunk. The wire from the skreem to the bcm are split and have a plug in the paasenders side under the metal plate where also the amplifier and the control unit for the automatic transmission is bolted on.
After disconnect and reconnect this plug all works again. We soldered than the wire together because the plug is only necessary to install the wiring harness.
Frantisek Siskovic
23
Sep 17, 2014 07:11 PM
ThatSweetSRT6
Sep 11, 2011 11:06 AM
kolevski
Jul 2, 2009 12:42 AM
Playdrv4me
Jun 20, 2008 08:41 PM
saldous
Feb 24, 2005 04:56 PM
