i thought it was just the fuel pump, but
Old Dec 19, 2018 | 01:39 PM
Nunyadam's Avatar
Default i thought it was just the fuel pump, but
driving down the road yesterday and my Crossfire just lost power and died. had it towed home, and the tow driver mentioned that it was leaking fuel.
before it died.
1. I was on my way to fill it (low fuel light had just come on)and head out for work.
2. some extra noise from fuel pump on cold start.
3. fuel filter was changed a few months ago, and car was running fine.
now.
1. fuel pump replaced. still didn't want to start
2. tried to add fuel and the vent door in the filler tube was stuck, used a long rod to open and add fuel
3. car will now start, idle at about 1100rpm and die a short time later, dies immediately if you try to rev the engine.
4. and now I see its dumping fuel on the ground when running, I guess I will be back after I find that leak.
Old Dec 19, 2018 | 01:49 PM
Nunyadam's Avatar
Default Re: i thought it was just the fuel pump, but
ok its from a hose on the big black box back by the fuel pump. whatever its called.
could part of the problem be from the old fuel pump clogging the pressure valve in the fuel filter?
new filter ordered.
Old Dec 20, 2018 | 02:25 PM
Nunyadam's Avatar
filter did the trick,
now to fix the fueling issue.
Old Dec 20, 2018 | 03:44 PM
blackcrossfire07's Avatar
Where did you get the fuel filter? The dealership wants 400+ to replace it. I mine as well do it myself.
Old Dec 20, 2018 | 03:45 PM
Who replaced the filter? The dealership quoted me 400+ dollars to replace my fuel filter
Old Dec 20, 2018 | 03:52 PM
I got mine from Rob at Needswings.com
Old Dec 20, 2018 | 05:14 PM
Is that the OEM fuel pump for $200? Which filter do I need? The high flow? Or get the one with a regulator? I have a base coupe.
Old Dec 20, 2018 | 08:55 PM
The high flow?
Contact Rob directly by email to confirm the correct answers to your questions.... sales@needswings.com
Old Dec 22, 2018 | 12:03 PM
NeedsWings's Avatar
you will want the updated fuel filter with 4 ports. (has internal regulator)
the high flow filter only has 2 ports and requires the use of our adjustable fuel pressure regulator kit.
Old Dec 23, 2018 | 02:03 PM
Nunyadam's Avatar
purging the evap system fixed the fueling issue!
05srtsix
Jun 4, 2017 01:21 PM
rmcdaniel12
May 9, 2015 01:55 PM
sponge
Jan 23, 2015 09:30 AM
KJKnowles
May 2, 2009 01:26 PM
MAYAman
Aug 5, 2006 01:05 PM
