Won’t start 2004 crossfire 11,300 miles
Old Jan 8, 2019 | 12:29 PM
craftykates@mail.com's Avatar
Default Won’t start 2004 crossfire 11,300 miles
replaced the CPS, Battery, RCM. Turns over, no fire. Ground is good. Fuses good, going to pull fuel filter next. I would start it every month, my husband got sick and it sat I know stupid. Any suggestions? All replaced with Bosch parts.
Old Jan 8, 2019 | 01:52 PM
Default Re: Won’t start 2004 crossfire 11,300 miles
Did you replace ot repair the RCM?
Old Jan 8, 2019 | 10:45 PM
Yes!
craftykates@mail.com , Today 09:29 AM
Old Jan 8, 2019 | 11:21 PM
It amazes me, but there is a fuse that power JUST the spark plugs. In nine years on here, I"ve heard of it blowing just twice.
If I were you, I"d check that fuse. Fuse 11 in the underhood (driver's side) fuse box in 2005 SRTs (and I think Limiteds - gotta be careful, they moved things around in the fuse box over the years and between SRT/Limited/Base models - make sure you look at the card under the lid for the right fuse).
Old Jan 9, 2019 | 12:56 AM
Do you hear the fuel pump running in the ACC position?
Old Jan 9, 2019 | 11:18 AM
I’ll check the fuses again, and yes I hear the fuel pump. Thank you for your reply’s!!!
Old Jan 9, 2019 | 11:30 AM
Did you actually install a NEW RCM?
Old Jan 10, 2019 | 11:11 PM
Duckthis1's Avatar
I'd give it a shot of starting fluid,if it fires you've got spark.
Old Jan 12, 2019 | 06:21 PM
Fuses all good !
Old Jan 12, 2019 | 06:23 PM
[QUOTE=ZERACER;917463]Did you replace ot repair the RCM?[/QUOTE
yes, I replaced the RCM
Old Jan 12, 2019 | 06:25 PM
I’ll check the fuel filter first, them I guess I’ll try starting fluid.
Old Jan 12, 2019 | 06:26 PM
the fuses are good, double checked.
Old Jan 12, 2019 | 07:56 PM
Once the engine is turning,you need air, fuel and spark.
I assume you are trying to start the car on the earth, so air should not be a problem.
You can always grab an old (or brand new) spark plug, yank a plug wire off, plug the loose spark plug on it and maybe ground said spark plug to the block with vice grips - turn engine over - the the plug firing? If not, fix that!
THEN, if you have spark, have someone turn the key to "ON" - for only a few seconds, you should have 55 psi of fuel pressure. This can be measured at the little valve on the end of the fuel rail.
That's how I'd go about it. If you find you have low or now fuel pressure, or no spark at all, you can go from there.
Old Jan 12, 2019 | 08:24 PM
thank you! That sounds like a good plan, I copied what you said. I am going to check it out. I am not really to keen on the idea of using starting fluid, as suggested. I like your idea. Thank you !
Old Jan 12, 2019 | 09:39 PM
I'm not so sure I DON"T like the starting fluid idea. We had it around all the time 40 years ago, and if you ever sprayed it in the intake while cranking and DID NOT notice the engine sputter, you had a good idea that there was no spark.
Old Jan 12, 2019 | 09:56 PM
*Moved to appropriate forum*
smmanley1996
Sep 4, 2015 04:40 PM
cx24724
Jul 12, 2015 11:57 AM
Raikyon
Dec 6, 2013 03:26 PM
TXCF
Aug 10, 2013 08:33 PM
siXFold
Jun 2, 2010 01:54 PM
