Stuck relay
Old Jan 13, 2019 | 09:09 PM
tripley's Avatar
Angry Stuck relay
I’ve got a large current draw. When I connect the battery I hear a “frying egg” sound coming from the same box as the RCM is, however it isn’t coming from the RCM, which I had replaced in the past. The car starts and runs briefly. I can start it and run it three of four times before the voltage drops too much. At that point it will not turn over. Any ideas?
Old Jan 13, 2019 | 11:46 PM
Default Re: Stuck relay
There is ONE way to find where current is going. You can ask for "ideas', you can guess, you can search youtube videos - or you can do the ONE thing that will give you your answer: remove the battery ground cable from the battery post, insert an ammeter, and start yanking connections until you find where the current is going. You will need the diagrams in the service manual as well.
But no one wants to hear it, so I will stand down while others toss guesses at you.
Old Jan 14, 2019 | 02:34 PM
tripley's Avatar
It’s drawing .01 amps across the meter, probably the four way flashers which are blinking. When I recharge the battery, I can get it to run momentarily three times. At that point the battery needs to be recharged. It seems to make little difference on the power draw if the key is turned on or off. I don’t have the sort of meter that will take the full amperage of starting. The starting three times is pretty predictable, I was thinking I might have a skreem issue, but for the battery being discharged. Any ideas?
Old Jan 14, 2019 | 03:49 PM
.01 amp is 10 milliamps - the spec is .045 to .055 amp. Your readings seem very low for a Crossfire.
And above all: If you have .01 amp flow with flashers blinking, your meter is not accurate. Not even close.
Again, your meter is bad or you do not have it connected correctly.
All of your talk about "three times and the battery is dead" and "it runs three times and..." makes me think the SKREEM is bad.
FACT: Starting the car three times will not discharge the battery. PERIOD. You are misreading what is going on, OR you have a completely defective battery. If the battery is dead after three starts, you need a new battery, PERIOD.
But again, it sounds like you have a bad SKREEM -but I am reading between the lines, I"m not standing next to your car so I can't say for sure, but nothing you have posted lines up. Your current readings are invalid.
Old Jan 14, 2019 | 03:57 PM
There is a fan that cools the black boxes components, but I would have thought it would have died long ago with your problems
Have you looked inside the RCM, it may be trying to run a seized air pump all the time. But the air pump has a fuse so it should have blown.
With that loss of powere so quick something has got to warm up really quick.
Are you sure the battery is good and has electrolyte in it. Does the battery get hot?
Is the starter/solenoid getting hot?
I am grabbing at straws here.
Old Jan 14, 2019 | 04:02 PM
Damn - I forgot about his "Frying Eggs" sound. But again, if he is seeing .01 amps with all this going on, his current readings are meaningless.
Old Jan 14, 2019 | 05:05 PM
tripley's Avatar
Battery is good, just months old and recharged by the parts store before this discharging episode. I just tried to start it again, three time started briefly then nothing, disconnected the battery, three times started briefly then nothing. The “frying egg” sound remains, but the battery doesn’t seem to be discharging as excessively. Flasher, fan or something intermittently stuck on? Now I’m thinking I’ve got a skreem problem. That will be interesting to solve as the keys are both not emitting signal, and you need to sink them to the car to complete the repair. I’m looking at a used ecm, skreem, door-ignition locks and key for $450 on fleabay? Anybody got a suggestion?
The car does not have a key which is working. What I’m thinking now is that I let the battery get discharged. Since I don’t have a working key, the skreem has nothing to sink to. I’m wondering if getting a working matching the VIN would do the trick. I see an ecm, skreem, ignition-door locket for sale on fleabay. I know a used skreem will not work. Will it behave with a matching ecm?
Old Jan 14, 2019 | 05:17 PM
tripley's Avatar
Question would a new key, matched to my VIN and the existing skreem fix this problem? (No working key, skreem lockout)
Old Jan 14, 2019 | 05:39 PM
Somehow I do not think we are getting all the facts. We now have the SKREEM symptoms. But .............?
Old Jan 14, 2019 | 06:52 PM
Yea, I'm lost. You say you don't have a 'working key' and you keep talking about "syncing" a key. Syncing the key has to do with the lock/unlock function, it has NOT A THING to do with starting the car.
When you put the key in the ignition and turn to "on" the skreem reads the RFID chip in the key. If the chip responds properly, all is good.
If the chip does not respond, or the SKREEM has gone bad, you get the "three cranks and nothing" symptom, this is a designed behavior to tell you/the garage that the SKREEM is not giving the ECM the "ok" to start.
I think the SKREEM is bad, unless someone has had the dash apart and they accidentally left the cable from the "Key RIng" (my term) unplugged from the SKREEM. Or you have replaced your key Fobs and didnt transplant the RFID chip to the new FOB.
Not sure what the "Frying eggs" and "battery drain" thing is all about.....
Old Jan 15, 2019 | 12:22 AM
JSK's Avatar
JSK
I’ve been following this thread and all I can say is “what?”
Old Jan 15, 2019 | 05:21 PM
Has the key FOB case ever been replaced? If the chip in the FOB wasn't moved over to the new case, it'll never start.
CrossfireRSSS
Dec 4, 2018 10:34 PM
mexico63
Apr 20, 2013 10:54 AM
thecollector
Jul 20, 2009 12:49 PM
Louie K
Aug 11, 2007 08:25 AM
Napasanaoma
May 25, 2006 09:39 PM
