180F low-temp Thermostat available
Old Jul 25, 2019 | 04:08 PM
WD40's Avatar
Default 180F low-temp Thermostat available
So many on this forum have asked if there were a lower-temp thermostat available but not so low that it'd cause the ECU to go into "startup" fueling mode. This should do the trick. It's compatible (in fact must be used) with the Mercedes-Benz 1132030275 thermostat housing (that's the OE Crossfire thermostat/housing gents!). The OE thermostat is 188.6F so your car should run about 9 degrees (F) cooler.
https://www.vrpspeed.com/product/mmts-mb55-03l/
Old Jul 25, 2019 | 04:20 PM
maggy55's Avatar
Default Re: 180F low-temp Thermostat available
This may be the same one, a little cheaper.
https://www.mishimoto.com/mercedes-e...2003-2006.html
Old Jul 25, 2019 | 04:30 PM
WD40's Avatar
Great catch. As they say, "Twenty bucks is twenty bucks!"
Old Jul 26, 2019 | 02:16 AM
WD40's Avatar
I just happened to have an OE Crossfire thermostat in the garage.
It comes already fitted into the aluminum housing. Yo see here the two "wings" on the thermostat which slot into these grooves on the housing. It's a secure pressure-fit between here and the second round stamping on the thermostat which seats into the housing...
...which you see here.
Inside the housing the pintle of the thermostat fits into this nipple-extension. I couldn't photograph at an angle which lets you appreciate the length of these pieces inside the housing.
I'm sure a machine fit the thermostat into the housing but ask yourself, "Is a machine more capable than you are?" :-)
srt6vic
Jun 2, 2021 09:48 AM
KDW4Him
Jul 6, 2018 03:04 PM
harbor
Aug 31, 2016 02:32 PM
vallartenses
Jan 19, 2013 07:35 PM
xfireon20z
May 11, 2012 08:27 AM
