Turn signal wiring
Old Sep 19, 2019 | 03:31 PM
Shamrock's Avatar
Default Turn signal wiring
Trying to locate wires to both left and right turn signal lamp. Is it in the headlamp connector? Color of wire for each? How do you get the connector off the housing? Can't find an alternate location to tap the circuit to add sequential turn signal strip to each front lamp. Thanks.
File Type: pdf
Old Aug 23, 2021 | 02:06 PM
cvpalmer's Avatar
Default Re: Turn signal wiring
turn signals not working left turn totally out right works once or twice and stops but emergency flashers work is there a fuse flasher on this car crossfire 2004 coupe
Old Aug 23, 2021 | 02:16 PM
zip439's Avatar
Before you start digging around into the wiring did you check for voltage at the bulb socket using a volt meter?
Chiminoul
Jul 8, 2021 08:53 PM
crazy
Jun 14, 2019 08:13 PM
D16
Mar 8, 2018 09:39 AM
D&D
Jun 27, 2007 09:27 PM
Robinhood
Jun 30, 2005 07:04 AM
